Feb 15, 2015 23:20:25 GMT
Hi all got a big problem !!
Got a s2 RS engine in my escort estate..... Was driving earlier hit boost then there was a almighty bang!!! Then loads of top end rattle!!! Was only running low boost
Any ideas on the problem would be helpful
Danny
scimjim
Club RR Member Number: 8
S2 RS turbo engine problemsscimjim
@scimjim
Club Retro Rides Member 8
Take the rocker cover off and have a look first - I've had CVH lifters fall apart and rockers come loose before.
S2 RS turbo engine problemsChasR
@chasr
Club Retro Rides Member 170
Feb 17, 2015 21:50:13 GMT
After doing that I would be tempted to do a compression test. What injection setup are you running? Also, what rotor arm do you have fitted? Is it one with a rev limiter built in or a simple resistor item?
Feb 18, 2015 23:56:26 GMT
Doing a compression test on Friday.... It's running mfi with a bogo rotor arm and motorsport development leads.... The engine was set up standard boost and power at power engineering before I got it.... It sat around for a bit before I did the swap I've put a brand new t3 on it with 360 bearings...... Was starting on three for a while and hunting but cleared up then this happened
