edk83
Sept 17, 2016 19:20:37 GMT
Well today we finished fabriacting the front strut brace, the bits just need drilling and bolting now. Also started reinforcing the firewall to mount the pedal box, chopped the accerator pedal off as I want to move it. Added some supports as I don't want it flexing under braking Needs drilling and bolting At the moment the steering column is mounted in the standard place on the pressed front panel, it flexes if any weight is put on it, added some tube to stop that. Also ordered a Morris minor clamp mount which I'm going to add later.
Last Edit: Jul 6, 2017 12:34:31 GMT by edk83
edk83
Sept 27, 2016 22:20:42 GMT
I decided the chinese slim quick release was a load of rubbish and bought a proper weld on job. It's many times better but still has a very tiny amount of play, not enough to notice though so acceptable. This is the slug and column Tig welded Also found a proper unicorn of an mgzr 160, 1 mature lady owner from new, 70k miles, hg and cam belt done 2 years go. Using this as a daily till I decide if I want the engine, the car is pretty rusty but the engine is really clean and its super quiet on tick over I got her to rev it over 6k neutral to test the vvc, she was panicing as it's only ever done the shopping! Interior is mint, full stainless exhaust and one of those full screen pioneer headunits that cost a stupid amount 10 years ago.
Last Edit: Jul 6, 2017 12:36:14 GMT by edk83
edk83
Sept 29, 2016 13:40:14 GMT
Seat frames all welded and painted
Last Edit: Jul 6, 2017 12:38:54 GMT by edk83
Sept 29, 2016 21:25:52 GMT
This is so wonderfully bonkers. I always wondered how easy/difficult it would be to build a fast Allegro. Love to see what this will look like when it's finished.
fogey
Sept 29, 2016 21:42:45 GMT
I fully understand the meaning of the musical term 'allegro', but 'fast' and 'allegro' in the same sentence = bonkers
Last Edit: Sept 29, 2016 21:43:02 GMT by fogey
edk83
Sept 30, 2016 9:53:23 GMT
It should be moderately quick, definitely fun on the twisty bits even if it doesn't have enough power to compete with anything properly fast.
Looks wise its not going to be a sleeper, but not radical either, keeping all the factory lines.
Thinking a small shot in Nitrous could be on the cards later, now Nos and Allegro in the same sentence - Lol
Last Edit: Sept 30, 2016 12:40:37 GMT by edk83
Kieran
Sept 30, 2016 10:23:32 GMT
I think you should just fit a Rover 75 Turbo motor.
Remappable for 200bhp, and 280bhp available on stock internals, just injector, turbo and management upgrades.
The Ashby Jackson fleet:-
1979 Mini Clubman 1.8 K series 1978 Skoda 110r Project 130RS K-oupe 1978 Austin Allegro 1500 SDL Estate 1984 BMW K100 Sidecar outfit 1999 Yamaha FZS 1000 Fazer 1991 Kawasaki ZXR400 race bike 2002 Kawasaki ZX9r race bike
edk83
Sept 30, 2016 12:40:07 GMT
It could happen in the future, or even a vag 20v turbo - have seen one in a metro using modded engine and gearbox arms. Also wondered if diesel would be different! The issue with the 75 turbo is that the turbo would probably need to be out over the gearbox as there isn't enough room at the front. I remember seeing how you'd shaped the front panel of the clubman to fit around the manifold of the K series. I've got enough room for the full mgf rad in front of the manifold but only just - having a turbo there wouldn't fit, and then I'd need an intercooler too. There is an Austin 1100 in Germany with the turbo in front of the engine, custom manifold. He is using a pair of small fiat rads each side of the turbo, but still has a big intercooler stuck out front. Going to get a vvc running in it first, stuff like the roll cage and suspension has taken up a fair bit of time but all things I want to get done Bodywork to sort out too!
Sept 30, 2016 17:42:22 GMT
just my opinion, but BHP for BHP, light short wheel base front wheel drive cars are better suited with normally aspirated engines. turbo engines, yeah great for big nubmers and cheap horsepower, but 100% of engine torque delivered in the space of 500 rpm unsettling said light fwd car while breaching the axpex of a corner, gets boring after a while.
edk83
So much work to do....
Last Edit: Jul 6, 2017 12:39:40 GMT by edk83
retrolegends
Winging it.....Since 1971.
Club RR Member Number: 94
Ive said it before and I'll say it again, those wheels are gonna look awesome!! 😆
Keep it up mate!
1974 Hillman Avenger 1500DL1992 Volvo 240SE1975 Datsun Cherry 100a flying custard1965 Hillman SuperMinx Rock N Roller1974 Austin Allegrat Mk1 1.3SDL1980 Austin Allegro Mk3 1.3L1982 Austin Allegro Mk3 on banded steels2003 Saab 9-3 Convertible 220bhp TurboNutter1966 Morris Minor 1000 (Doris) 2019 Abarth 595C Turismo (not retro but awesome fun) www.facebook.com/DatsunCherry100a
edk83
Oct 12, 2016 12:46:50 GMT
Last Edit: Jul 6, 2017 12:42:03 GMT by edk83
That looks really good mate following you with some interest as may be a route I will go down later after I've had my fun with a tuned 1300gt engine. Another option and a challenging one at that would be the 2.5 kv6 From a rover 75 would sound very sweet on strait pipes, However that's a crack in build your doing .
edk83
Thanks mate, Jonny has fitted a kv6 into his Allegro fabricating engine mounts and front shock towers, using golf hubs and brakes I think. The problem he found is that there is no room for the rad and it's going to have to move to the boot. I've managed to fit an mgf rad in quite nicely so sticking with that plan for now. Here is a thread that might be of interest to you - K series in an Austin 1100 - now gone turbo! www.16vminiclub.com/forums/showthread.php?t=35909Shock Cannons! Back from the bead blasters and rolled some 3mm plate to make the tubes. Now to figure out how long they want to be and put the ends / shock mounts on.
Last Edit: Jul 6, 2017 12:42:46 GMT by edk83
andy-v
i like cookies :D
Oct 13, 2016 10:38:50 GMT
excellent work
Thanks mate, Jonny has fitted a kv6 into his Allegro fabricating engine mounts and front shock towers, using golf hubs and brakes I think. The problem he found is that there is no room for the rad and it's going to have to move to the boot. I've managed to fit an mgf rad in quite nicely so sticking with that plan for now. Here is a thread that might be of interest to you - K series in an Austin 1100 - now gone turbo! www.16vminiclub.com/forums/showthread.php?t=35909Shock Cannons! Back from the bead blasters and rolled some 3mm plate to make the tubes. Now to figure out how long they want to be and put the ends / shock mounts on. I found the other allegro v6 yesterday that will be some machine when completed, Space is always the enemy I guess when shoe Horning in bigger engines , The 1100 link I've seen that one on the 16v forum that is a really nice looking car and some amazing work done there the way he made the rear disc set up I would never thought of that ! Anyway not to take any lime light away from your thread keep it mate I will be taking notes for later liked the possible bhp potential from the k series that's a big scary but we'll worth the fun you'll get .
edk83
Oct 15, 2016 17:09:41 GMT
Card templates now in steel Welded on with some captive bolts Now has an arb at the back Wondering if it could do with some extra bracing to the boxes. Boot floor is rather thin although they are both welded neatly into the corners.
Last Edit: Jul 6, 2017 12:44:48 GMT by edk83
edk83
Oct 16, 2016 18:43:25 GMT
Added extra steering column support today, the clamp is from a 1930s car! Just happened to be the right diameter and two sections.
Last Edit: Jul 6, 2017 12:45:35 GMT by edk83
edk83
Last Edit: Jul 6, 2017 12:48:26 GMT by edk83
village
Always carries a toolbox. Because Volkswagen.......
just my opinion, but BHP for BHP, light short wheel base front wheel drive cars are better suited with normally aspirated engines. turbo engines, yeah great for big nubmers and cheap horsepower, but 100% of engine torque delivered in the space of 500 rpm unsettling said light fwd car while breaching the axpex of a corner, gets boring after a while. I would tend to agree, with the small exception that edk83 mentioned diesel engines earlier on, and I love a nice torquey derv lump, which would be pretty epic in a lightweight hatch like this, there are plenty of VAG diesels that would likely be made to fit. just take a Skoda Fabia VRS for a spin to see what I mean....
Last Edit: Oct 26, 2016 9:08:11 GMT by village
"The White Van is strong with this one...."
Chris "Chesney" Allen 1976-2005 RIP
