Oct 11, 2015 17:20:59 GMT
So, Once the front end chassis mods were done allowing me to mount wishbones and shocks where I wanted to, the next step was to buy said shocks.... ...a couple of phone calls to Protech in the South West and I have some shocks! They're a custom length- actually slightly longer than a standard imp shock and the helper springs are there to ensure the main spring remains in contact with the seat on full droop. Both front and rears are double adjustable and protech supply the damping curve... more for my to plug into and uber spreadsheet and my dynamics model.
Oct 11, 2015 17:42:05 GMT
As I mentioned in some other threads, I have been lucky enough to procure some Hayashi Streets, which I had shipped over from Japan. This presents a problem in terms of mounting them.... Imp PCD is 4x101.6mm (4x4") The PCD of the wheels is 4x114.3mm Re-drilling the hubs isn't an option- not enough meat on them Adapters is not a solution in my mind either- it's a cheat, not a "proper" solution So I started exploring other options. >The first was to find suitable hubs from another, donor vehicle. Throughout this build, I am trying to make sure that it is a build for longevity. I.e. if I take parts from other cars, I hope to choose some which will be readily/easily available in years to come. 4x114.3mm is common on a lot of older Japanese cars, and some less old ones- like hyuandai coupes and nissan primeras. So, on the rear of imp, I have elected to use a Nissan Primera front hub- this gives me a suitable spline for a drive shaft and the right PCD. In order to mount the hub to the arm, a Kia Pride wheel bearing will be used- this is only 1mm greater than the standard imp wheel bearing and the correct inner diametre for the primera hub. However, on the front- whilst there where available hubs that could have been made to fit the imp stub axle, they were much bigger and heavier. They also would have required the imp stub axle to be turned down and sleeved, in order to get the bearings to fit- which I wasn't sure about as a robust solution. Thankfully, this forum is full of very skilled, clever individuals, such as a certain Johnny Dennett who it turns out is a bit of a dab hand in a machine shop! Offering lots of advice on the way, including taking receipt of my new wheel bearings to ensure they would fit correctly, Johnny has sorted me out with some VERY good looking hubs. Almost too good looking to fit to the car, especially with their sexy zinc coating! Massive thanks Johnny
Oct 11, 2015 17:56:20 GMT
Great to see it all coming together !
eternaloptimist
Oct 11, 2015 19:26:10 GMT
Looking forward to seeing this come together. Really miss my old Imps. Kept all the manuals and tuning books, one day....
Not to second guess your decision, but why not use 180sx/Silvia rear hubs? Most people swap from 4 stud (4x114.3) to 5 (5x114.3) to run larger wheels, so they can be had cheap on drift forums etc. That way, they're already Rears for a RWD, have a big aftermarket scene and you can get a brake upgrade as well.
Oct 12, 2015 10:07:35 GMT
There's plenty of hubs that would work tbh, but the hyundai ones are cheap and easy.... £20 or so brand new.
Although now I think about it they might be Nissan Primera... should probably check the box!
Oct 12, 2015 13:07:48 GMT
Frank, it's great to see you've still got FAF!
Selling FAF back to you in 2011 was really sad, and I massively regret selling that car... BUT... to see that you've still got it makes me feel a lot better about it - glad that it returned to it's rightful owner!
I can only say good things about the 998 engine I fitted - it absolutely flew with the lightened/balanced/ported polished bits and chesman head - if one comes up for sale, grab it.
Owned, restored and sold on... 1960 Mini Van 1970 Hillman Imp 1972 Hillman Imp 1979 Volkswagen T2 1981 HL Estate 1991 Mini City 1999 Mini Cooper
Oct 12, 2015 14:40:01 GMT
Damn fine piece of engineering!
Oct 12, 2015 15:18:27 GMT
Hi Chris, Nice to here from you (don't supposed you still have the left over paint do you)! I can only say good things about the 998 engine I fitted - if one comes up for sale, grab it. Oh, I won't be needing that... plans (from the previous page) have changed....
bazzateer
Imping along sans Vogue
Oct 12, 2015 18:22:39 GMT
Hi Chris, Nice to here from you (don't supposed you still have the left over paint do you)! I can only say good things about the 998 engine I fitted - if one comes up for sale, grab it. Oh, I won't be needing that... plans (from the previous page) have changed.... Some Bavarian brawn eh Frank!?
Oct 12, 2015 21:10:11 GMT
Anyone would think you already knew Baz!
looking good frank !
Play'in round with an old Datsun & a Ford COE
bazzateer
Oct 13, 2015 18:26:08 GMT
Anyone would think you already knew Baz! Just wish I could afford to get mine done sooner!
Oct 14, 2015 10:13:10 GMT
No paint left sorry Frank, I think it was used as base coat many moons ago!
Oct 14, 2015 13:44:01 GMT
Just found this.. Bookmarked!
Oct 18, 2015 15:39:28 GMT
So.... Brakes! With the suspension mostly sorted and front hubs done, I've decided to turn my attention to the brakes, which I've been quite looking forward to, because it gives me the chance to do some maths and I'm a nerd, who loves maths. I'd already decided that I was going with front and rear discs because.... well.... why not? Front disc conversions do exist for the imp, typically based on fiesta or Micra parts, however, all you're really paying for with one of those kits is a set of discs re-drilled to suit imp PCD, hoses and a set of brackets to mount the calipers. You then have to go off and find suitable calipers etc. Having changed the PCD therefore, one of the key parts of the kit (the redrilled discs) is redundant! I had previously bought a disc conversion, but the subsequently got sold on eBay. Also, I get a bit OCD about stuff and re-drilled discs (same as PCD adapters) just isn't "proper" enough for me and I was a bit underwhelmed by the quality of the caliper brackets. So.... maths time! In terms of braking specifications, one of the most important things to get right (IMO) is the balance between front and rear. Yes, you can use a bias bar or a prop valve to correct the balance, but I would rather have that as an option for tuning a system that is close to being right, not depend on it! First thing I did was to use the drum radius and piston sizes of the standard system to understand what the Rootes engineers thought the balance should be (one factor I left out was the "shoe factor" which shifts the bias slightly towards the front due to the effect of the twin leading shoe at the front). Then, using estimations for the longitudinal position of Centre of Gravity and the Centre of Gravity height, as well as front/rear static weight distribution (yup, lots of guess work!)... I looked at what the weight distribution is (roughly) likely to be under braking. Too much rear bias- the rears will lock as weight is transferred to the front axle under braking and you'll go backwards into a wall Too much front bias- your front tyres will reach the limit of adhesion too quickly, they'll lock up and you'll have LESS braking available due to the under performance of the rear brakes For the record... I LOVE a spreadsheet. I did have a brief foray into Wilwoods- there's a massive range of products and plenty of technical specs/details with them, making them easy to work with. But when I bought a caliper, it was MASSIVE and didn't even come close to fitting in the wheel. So I decided to go back to floating single pot calipers from a production vehicle. Next came LOTS of parts catalogue trawling. For discs, I find the Apec catalogue to be FANTASTIC: www.apecbraking.co.uk/catalogue/sizeI simply searched for suitably sized discs from vehicles that I know have a suitable PCD (4x114.3mm), such as 90s Nissans and Hyundai coupes. - The reason being I want to make sure that service parts such as discs will be readily available in years to come, preferably without modification. And for calipers, the key consideration is the piston diameter, for which the website brakeparts.co.uk is excellent (although you do have to search by vehicle. I just tried lots until I found something): www.brakeparts.co.uk/#!/shop/ROVER/MGF/95-02/MGF 1.8 MODELS inc VVTI/Front - Brake Calipers and Wheel cylinders Using my spreadsheet, I arrived a MGF front and rear calipers, which should provide an excellent front/rear split consider the imps weight distribution and rear slung engine. The MGs feature 240mmx22mm vented discs front and rear. As it turned out, whilst I was also able to find a 240x22mm vented disc from a Nissan Primera, I also found a 256x22mm disc, which I will use on the front. This shifts the braking slightly towards the front, which is the "safer" option vs the rears locking and can be tuned out with a bias bar if need be. The numbers show that they are ~1% from the standard imp set up (excl previously mentioned shoe factor).
Oct 18, 2015 16:20:06 GMT
So, with the parts sorted, it's time to work out how to mount the calipers to the imp suspension. I've always wondered, when fitting different calipers and designing brackets for them to mount, how you establish what the PCD for the caliper carrier mounting bolts is. It's important, in order to make sure that the pad is positioned correctly in relation to the disc. To do this, I mounted a piece of card over the disc. Filed a bolt to a point Place the caliper over the disc (and card). Then used the bolt (with a bit of paint on) to mark the two bolt holes. I then moved the caliper round the disc and marked the same two bolt holes again somewhere else on the card. I also did the same with the stub axle (to which the caliper bracket will need to mount): By measuring the distance between the points, you only need 3 points about the circumference of a circle to find it's centre/radius, so I was now sorted. It can be done by hand/on paper, but I just plugged them into a CAD packaged instead. So now I know what two diametres the sets of bolts need to be, I started work on a flat bracket out of carboard and flat sheet steel, before carrying on to draw up a bracket to suit. I've got a 3D print of this on the way, so that I can make sure all is good, then I'll get one made up in steel. It's a bit tight under there, bit not too tight!
eternaloptimist
Oct 18, 2015 18:27:23 GMT
Good work there!
Oct 18, 2015 19:21:55 GMT
Once you have all the calipers mounted up and work out the length of the flexi needed drop me a PM as I can get them made up cheaply in stainless braided
Cool, sounds good Swampy, I'll be sure to give you a shout!
