3 o'clock saturday afternoon: grinding off some bits and pieces of bodyworkfrom a cortina shell, before it gets weighed in - almost finished when the grinder packs up >:(AAAARRRRRRGGGHHHHHHHH * searches for chisel and 4 pound hammer
Last Edit: Jun 2, 2007 14:13:52 GMT by Autofive
AAAARRRRRRGGGHHHHHHHHBenzBoy
@benzboy
Club Retro Rides Member 7
* searches for chisel and 4 pound hammer Me and Street recently removed the entire front end of an Escort with wood chisels and hammers. It was painful.
3 o'clock saturday afternoon: grinding off some bits and pieces of bodyworkfrom a cortina shell, before it gets weighed in - almost finished when the grinder packs up >:(AAAARRRRRRGGGHHHHHHHH * searches for chisel and 4 pound hammer Yep I've had that... it's at that point that you wish you'd forked out for the £30 grinder rather than the £15 one!
Nick
Range rover shell removed from the rolling chassis with a hacksaw, and a large wood Axe has been my best/worst...
-Cas on Nicks computer
Last Edit: Jun 2, 2007 16:16:38 GMT by Nick
this weeks car count "5"
Odin
We spent most of yesterday 'removing' a totalled body mount bolt on my bug with a variety of drills, chisels, hacksaw blades and all the tools I could find for the dremel. It's sunk into the bracket y'see, and made of some incredibly strong substance.
chopped a rotten mk2 escort into bits with a hay sickle and a lump hammer and bolster chisel in ireland with uncle shay about 20 years ago ;D
2001 HONDA CT110 (NOT RCV)
started with the chisel, and a sharpened jemmy - gave up agter about ten minutes - as I wasnt getting far - it was indeeed a cheap grinder, 7 quid + postage from ebay about 15 monthes ago
cutting the grass instead now - its safer - and i get brownie points
cut the hedge then put my back out. Spent two hours practially unable to move, rest of the day simply in agony. All Ibuprofen'd up now. Next job was to deal with the Oldsmobile window winder cranks so I'm behind - again!
Ive cut the front end off an allegro using a bolster chisel and lump hammer. Took ages and really REALLY hurt. I overran my lunch break at work by 2 hours. Nearly new front panel tho so worth it.
1987 Maestro 1.6 HL perkins diesel conversion 1986 Audi 100 Avant 1800cc on LPG 1979 Allegro Series 2 special 4 door 1500cc with vynil roof. IN BITS. HERITAGE ISSUES.
we cut the roof off a mini in a similair fashion once with chisel and hamer would have been quicker with a tin opener
spacekadett
F*cking take that Hans Brrix!!
Removed the drivers wing on JS's donor Mk1 'scort with bare hands! To be fair it was as rotten as sh1te in the pillar and valance. Did look impressive tho Dispatched the rest of the car with a combination of a 4.5" and a 9"grinder, hammers and chisels. On the subject of cheap grinders I usually keep a couple on the go in the workshop, so when one packs up you can still finish the job
Mechanic's rule #1... If the car works, anything left on the floor after you finished wasn't needed in the first place
