pork
Jan 31, 2015 11:46:55 GMT
I've decided to move the throttle on my supercharged micra engine, so that its pre charger now.
But beings I'm doing this it'll give me a chance to change the t/b.
Question is, what size should I use?
Engine is a cg13de (1.3l) Charger is a m24 eaton from golf tsi I will be using a charge cooler too if that matters.
Current t/b is from a starlet and is on a starlet manifold too and has od of 57mm but tapers down inside
Jan 31, 2015 11:55:42 GMT
whats the projected bhp & rpm?
pork
Jan 31, 2015 11:57:19 GMT
140-50?
froggy
Jan 31, 2015 13:55:21 GMT
worlk out the volume of the charger , pipe work , chargecooler and inlet manifold . It will be 3-4 times the original manifiold volume so you will end up with idle issues and fueling in cruise ,leave the original throttle where it is and put one in front of the charger . Common mod on charged mx5s and I ran two throttles on my ten charged build which worked well
slater
Club RR Member Number: 78
Throttle body sizeslater
@slater
Club Retro Rides Member 78
Jan 31, 2015 16:33:27 GMT
So your moving the throttle after the blower or before? Be quite interested to see more details of the project as ive been 'discussing' this sort of thing on anther forums. What kind of bypass do you run?
As for the original question, personally i don't think it matters too much, 50mm would be plenty i should think. With injection its not too critical as you don't have to worry about velocity so much but if you fit a bigger throttle you will loose sensitivity at low throttle openings. Some bodies use a progressive linkage to combat that.
pork
Jan 31, 2015 16:52:11 GMT
Link to build should be in my signature Was twin charged, but sold turbo and other stuff, so just gunna have supercharger on its own now
slater
@slater
Jan 31, 2015 17:01:40 GMT
Mmm thats going to take a bit of reading!
pork
Jan 31, 2015 17:17:34 GMT
Haha, goes on a bit, supercharger and efi is near the end.
Started off as boosted bike carbs
slater
@slater
I think the best advice for you is to have a sit down and think about what your doing before you do it!!
pork
Maybe, I prefer to build it and see if it works,
slater
@slater
By the look of the thread you have had about 10 incarnations and none of them have worked. (All of them could have worked tho)
Still, ditching the bike carbs was probably your best move.
pork
The bike carbs were ok.
The last variation of super/turbo worked really well
pork
just needed money so that's why I sold the turbo stuff along with other parts
