Mk2 Escort 4 Door 1.3l in Beige
Good solid Shell, needs passenger rear wheel arch welding correctly, drivers side rear wheel arch inner and outer, also petrol tank well
Boot floor is absolutely mint Roof is mint, no rot at all and none sunroof from factory
Both inner and outer sills are in good order, floor pans are good, two plates welded in the fronts otherwise original
Strut tops, bulkhead, wing rails are all welded up and filled and all the engine bay is primed up almost ready for paint, new kick panels and a posts are in good order
Both scuttles are good as new, no rot at all
Chassis rails are solid no rot other than the odd bit of surface rust
All 4 doors are in reasonable condition, including glass
This is a bare shell including boot lid and all 4 doors, however can be made rolling for the right price
The panels required for this shell are bonnet, drivers wing and front panel
Drivers rear inner and outer arch repair panel included, also petrol tank well repair sections included in sale
Logbook present, chassis number present in original strut top
More pictures can be provided on request
Viewing is recommended and welcomed
May cut this up if enough interest in panels
I will consider PX classic fords WHY
£1000 bare shell
£1200 Rolling shell
I will listen to any sensible offer - 07964 838838
