slomoshun
Going forward one nut and bolt at a time
Jan 26, 2015 17:26:33 GMT
Changing steering wheel after mot on my Rover 820 to a dished sport wheel. As car as airbag which will no longer be in use i will fit a resistor the common way to bypass the air bag light. What one will i need ? Thanks in advance for information. I know air bags are there for a reason but I'm not the first or last to do this conversion.
Traction and horsepower is nearing perfection
Rich
Club RR Member Number: 160
Air bag resistor info neededRich
@foxmcintyre
Club Retro Rides Member 160
Jan 26, 2015 18:15:53 GMT
2-4 ohms should do it. Get a selection from maplin within that range and try it.
slomoshun
Jan 26, 2015 19:08:24 GMT
Thanks Rich for info
slomoshun
Jan 27, 2015 21:05:31 GMT
anyone know of an air bag list that tells you correct resistor to fit if changing to sport steering wheel doing away with airbag thanks
Rich
@foxmcintyre
Jan 27, 2015 21:57:09 GMT
anyone know of an air bag list that tells you correct resistor to fit if changing to sport steering wheel doing away with airbag thanks ..2-4 ohms. Like I said. I have this info from an auto-electrician. There is not a 'list' that I know of, it's comes from trial, error and experience.
slomoshun
Jan 28, 2015 11:28:30 GMT
thanks 2ohm being a minimum and 4 ohms a maximum onder if 3 ohms down the middle would be ok trying to get it right first time so don't trip out the air bag light needing resetting at garage
Rich
@foxmcintyre
Jan 28, 2015 12:10:01 GMT
3 ohm sounds fine but there is no promise it'll work straight up. Does the car have any other pyro-electric airbag Equipment or just the drivers squib?
Rich
@foxmcintyre
Jan 28, 2015 12:12:09 GMT
Also, what year rover 800 is it as some had a proprietary airbag diagnostic connector that I doubt any garages still have.
slomoshun
Jan 28, 2015 14:46:20 GMT
passenger side as airbag thats it / mine is later mk2
Jan 28, 2015 15:15:13 GMT
Do you have a multimeter? Unplug it and test across the terminals, it will tell you exactly what resistance it is in ohms. Then you can buy one the same, eBay have loads of choice
Last Edit: Jan 28, 2015 15:16:07 GMT by fuldatramp
slomoshun
Jan 28, 2015 15:37:01 GMT
no multimeter but when you buy momo wheel they supply a generic resistor so assume they expect it to fit all which might not be the case don't think many people change steering wheel on 820 as most are owned by anorak owners who would see it as a big no no but I'm different and want something a tad different taken me few months to source a boss kit but thanks to 820 on here he put me in right direction
Rich
@foxmcintyre
Do you have a multimeter? Unplug it and test across the terminals, it will tell you exactly what resistance it is in ohms. Then you can buy one the same, eBay have loads of choice No. No no, don't ever do that. To test ohms, multimeters output power, which is what sets airbags off. It's admittedly unlikely, but I'd never risk that myself.
Jan 30, 2015 17:17:31 GMT
Do you have a multimeter? Unplug it and test across the terminals, it will tell you exactly what resistance it is in ohms. Then you can buy one the same, eBay have loads of choice No. No no, don't ever do that. To test ohms, multimeters output power, which is what sets airbags off. It's admittedly unlikely, but I'd never risk that myself. I had a couple of multimeters out today and decided to test to see what the output power was during testing for resistance, my fluke gave out 0.2V and 0.22mA giving a wattage of 0.00004 watts - an LED usually takes around 20mA or (0.044Watts), so a meter is low low power I googled how much power it would take to activate an airbag but didn't come up with anything conclusive, personally I think the multimeter is so low power voltage and current (which is restricted and fused) that it wouldn't set an airbag off especially when you consider that normal activation voltage will be 12v
Rich
@foxmcintyre
Jan 30, 2015 18:05:42 GMT
No. No no, don't ever do that. To test ohms, multimeters output power, which is what sets airbags off. It's admittedly unlikely, but I'd never risk that myself. I had a couple of multimeters out today and decided to test to see what the output power was during testing for resistance, my fluke gave out 0.2V and 0.22mA giving a wattage of 0.00004 watts - an LED usually takes around 20mA or (0.044Watts), so a meter is low low power I googled how much power it would take to activate an airbag but didn't come up with anything conclusive, personally I think the multimeter is so low power voltage and current (which is restricted and fused) that it wouldn't set an airbag off especially when you consider that normal activation voltage will be 12v Kudos for testing! Still, wouldn't want to risk it, but it looks even less likely that it could happen.
slomoshun
Jan 30, 2015 18:34:50 GMT
Jan 30, 2015 22:34:41 GMT
I had a couple of multimeters out today and decided to test to see what the output power was during testing for resistance, my fluke gave out 0.2V and 0.22mA giving a wattage of 0.00004 watts - an LED usually takes around 20mA or (0.044Watts), so a meter is low low power I googled how much power it would take to activate an airbag but didn't come up with anything conclusive, personally I think the multimeter is so low power voltage and current (which is restricted and fused) that it wouldn't set an airbag off especially when you consider that normal activation voltage will be 12v Kudos for testing! Still, wouldn't want to risk it, but it looks even less likely that it could happen. [ Thinking about it, there must be a voltage/current running through it all the time (or at least at startup) to let the car know that the airbag is healthy and undeployed, otherwise you get the fault light up, (I would imagine after an airbag has deployed the circuit would go open curcuit and bring up your fault code/indication - the same as being unplugged) So if your car is passing voltage/current through it you should be ok with your meter
