Hi all,
Welcome to a pretty comprehensive advert for a Volvo S70, I've tried to be as honest as I can and photograph everything. I'm based in Andover Hampshire and have the car advertised elsewhere to aid sale.
Volvo S70 2.5 20v turbo (5cylinder 189bhp)
Manual.
Catback straight exhaust sounds ace - see video below.
Blow off valve.
Does 30mpg in and around town can get higher cruising on motorway (has a trip computer with many functions)
Just ticked over 154k miles.
11 months MOT no advisories.
No warning lights and idles where it should etc see photos for proof.
Electric windows all work from their own doors but passenger front window switch on drivers door has broken (can see in photo)
Heated seats and mirrors (though the switch above needs to be replaced for the mirrors to move as its on the same circuit but they heat just fine)
Parking sensors, air-con, power steering, dual climate controls, half leather interior no rips or marks on seats but rear door needs gluing back up (can see in photo)
Had new oil, filter and new battery in the last month.
Very reliable car, doesn't smoke at all.
It's not really a problem but I'm being truthful, when riding the clutch the release bearing squeals a little but it doesn't and hasn't affected the use of the car at all to the point where it doesn't make the noise if you use the clutch properly.
A lot of car for not a lot of money £500 Ono I have two cars and am selling the more expensive one if you offer the right amount I may bite your arm off.
Bodywork is as seen in photos its not that bad for a car of its age.
I look forward to answering your questions.
Manual.
Blow off valve.
