2.0 Zetec silver top
Ford type 9 box
Motorbike carbs (was sold them as being jetted for a 2.0 but cant confirm)
Motorbike carb manifold
Starter motor
Modified sump
Motor bike fuel pump.
Basically nearly everything you need, will need to make an exhaust manifold.
I had it running in my Humber but only briefly before buying a house got in the way.
Bought from Dez on here, had a new cambelt and water pump.
Starter was new but has a little surface rust from being sat around.
Ally inlet manifold
The bike carbs were from a running 2.0 engine that i bought in good faith, unable to confirm it has been jetted but i was told it is.
Also the box has been converted to hydraulic clutch with a concentric slave (cost a fair amount)
Has been painted British leyland green so it didnt look out of place in my Humber
Located in Weston super Mare
Looking for £500, id get more if i sell it all separately but would rather have it go like this.
Ford type 9 box
Starter motor
Modified sump
Ally inlet manifold
