SambaS
Jan 17, 2015 12:32:03 GMT
Is there any right or wrong way to tighten these?
I had one snap and had to replace it.
Noticed some seemed loose where others didn't, tightened all up.... engine wasn't happy.
Backed all off and now it seems fine.
1. 1988 Dacia Duster Pick-Up
2. 1992 Daihatsu Charade GXI Automatic
3. 1982 Ford Escort XR3
4. 1989 Ford Sierra RS Cosworth
5. 1984 FSO Polonez CE
6. 2002 MG ZR 105
7. 1984 Opel Monza GSE Automatic
8. 1982 PK Jimp
9. 1984 Talbot Alpine LE
10.1984 Talbot Samba Cabriolet
11.1984 Talbot Samba Roller
12.1986 Talbot Samba Style
bstardchild
Club RR Member Number: 71
Opel Monza 3.0 Rocker Armsbstardchild
@bstardchild
Club Retro Rides Member 71
Jan 17, 2015 13:29:55 GMT
Is there any right or wrong way to tighten these? I had one snap and had to replace it. Noticed some seemed loose where others didn't, tightened all up.... engine wasn't happy. Backed all off and now it seems fine. Very much a proper way - cyl where you want to check rocker clearances needs to be at TDC Rule of nine cuts down the time it takes and the number of engine rotations by hand
Jan 17, 2015 14:34:56 GMT
hi there
aren't these fitted with hydraulic tappets ?
tighten them down until free play in the arm has gone and then 1/2 turn to preload the hydraulic tappet.
when the arm / valve is in the closed position.
Cheers - mike
SambaS
Jan 17, 2015 16:23:01 GMT
Yeah hydraulic, I just tightened it up so the bolt position looked like the other 11
6. 2002 MG ZR 105
8. 1982 PK Jimp
bstardchild
@bstardchild
Jan 17, 2015 20:00:28 GMT
hi there aren't these fitted with hydraulic tappets ? tighten them down until free play in the arm has gone and then 1/2 turn to preload the hydraulic tappet. when the arm / valve is in the closed position. Cheers - mike That should result in all the valves burnt out in fairly quick time
Jan 17, 2015 20:23:06 GMT
why's that?
hydraulic tappets have preload.
probably whats happened is the hydraulic tappet pumped up due to broken rocker. they take a while to bleed down again so may be rough running for a while after adjustment due to the valve being held open.
as said get the valves to the closed position and then set the rocker preload.
if in doubt consult a workshop manual.
Last Edit: Jan 17, 2015 20:24:01 GMT by Bozwell
bstardchild
@bstardchild
Jan 18, 2015 20:24:33 GMT
why's that? hydraulic tappets have preload. probably whats happened is the hydraulic tappet pumped up due to broken rocker. they take a while to bleed down again so may be rough running for a while after adjustment due to the valve being held open. as said get the valves to the closed position and then set the rocker preload. if in doubt consult a workshop manual. Sorry - not all Monzas have heads suitable for unleaded - set the clearances for a unleaded head and everything is fine as there is no valve seat recession - set the clearances for a head that's not suitable for unleaded and you will get some valve seat recession over time If you get valve seat recession you'll get burnt out valves That's why I'm not to keen on full pre-load on hydraulic tappets in CIH engines
Jan 19, 2015 21:42:25 GMT
you've lost me. is it clearance or preload?
bstardchild
@bstardchild
Jan 19, 2015 23:00:23 GMT
you've lost me. is it clearance or preload? On unleaded heads - preload - up to 1 turn My caution with this is because there are a lot of Monza 12V CIH engines that don't have hardened valve seats On leaded heads - I'd want as little preload as I could get away with - simply because valve set recession is gonna add to the pre-load If it rattles like heck then you have clearance but don't assume just because they are hydraulic tappets that winding in a turn of pre-load is a great idea
your still confusing me with your description. so your saying put in a tiny amount of preload to take up any valve resession which will cause more preload, yet valve resession is caused by preload? i think i know what your trying to say and saying clearance really confused things where i guess you mean a little preload or standard/a lot of preload. i can't see that valve seat resession is caused by the hydraulic tappets though. i would say going by your description the hydraulic tappets are preloaded less to compensate for a longer time for valve seat resession before the tappets bottoms out .
bstardchild
@bstardchild
your still confusing me with your description. so your saying put in a tiny amount of preload to take up any valve resession which will cause more preload, yet valve resession is caused by preload? i think i know what your trying to say and saying clearance really confused things where i guess you mean a little preload or standard/a lot of preload. i can't see that valve seat resession is caused by the hydraulic tappets though. i would say going by your description the hydraulic tappets are preloaded less to compensate for a longer time for valve seat resession before the tappets bottoms out . It appears that you can put it into words better than I can
