May 28, 2007 20:00:38 GMT
what size tyre should I put on the cortina ghia alloy? I need four Summer tyres, (they will be replaced in sep/oct from 'sports' steels and winter tyres) - standard for the cortina ghia is 185/70 or 65?/ 13 and as the 2.3 has power steering, and Iam intending to run standard springs, I am debating the pros and cons of width and profile any thoughts?
Last Edit: May 28, 2007 20:01:08 GMT by Autofive
stinkwheel
Doctor Of Gonzo Journalism - One of gods own proptypes, never even considered for mass production.
May 28, 2007 20:02:47 GMT
i thought they had metric alloys? i know some of the granadas with a similar wheel design were metric.
1973 Citroen Dyane 6 1980 Citroen Acadiane 1992 Citroen AX 1990 Citroen BX 1997 Citroen XM 1993 Citroen BX 1997 Citroen Xantia 1977 Citroen Ami 8 1996 Ford Escort 1989 Citroen BX 1997 Suzuki RF900 1988 Yamaha TDR250 1979 Honda CB400. 'I need less vehicles'
May 28, 2007 20:03:08 GMT
If you're not lowering it then I think I'd stick with the standard size.
May 28, 2007 20:09:41 GMT
I thought they had metric alloys? I know some of the granadas with a similar wheel design were metric. i think its only the 5-stud wheel ghia alloy that was metric (390)
May 28, 2007 20:12:22 GMT
If memory serves me right, 175/70x13
slater
Club RR Member Number: 78
WHAT TYRE? - ford ghia alloysslater
@slater
Club Retro Rides Member 78
May 28, 2007 20:20:40 GMT
175/50s and a jack up kit!
Last Edit: May 28, 2007 20:20:51 GMT by slater
May 28, 2007 20:34:34 GMT
go with the 185/65 option as it won't look so balloony the 70's look like van tires
May 28, 2007 20:36:36 GMT
sorry, did you mean standard or something different?
May 28, 2007 20:37:20 GMT
go with the 185/65 option as it won't look so balloony the 70's look like van tires that was the 'con' of 70's - pro was softer ride no-one got any thoughts on tyre width?
185/60... Ford and Vauxhall used these as "interchangeable" sizes optionally on their cars back inthe day as a extra cost option. Can't have messed with the speedo grearing too much so should maintain about the same profile with a little more rubber. I've run 185/60s in place of 165R13, 175/70 and the like.
sorry, did you mean standard or something different? i was thinking about the wider subject, and wondering about other alternastives to standard e.g. - would a 205/60/13 be too wide for the standard alloy?
I have run a 195/50x13 on a standard steelie designed to take a 5.20x13 crossply (or a 165R133 radial) and that worked well.
what size tyre should I put on the cortina ghia alloy? I'm sorry - I'm not sure I can help you with the question, but I do love the advert - "Ford have restyled the saloon body shape with bigger windows and slim pillars to give even greater visibility" How times change: If only they had the same engineers today - modern cars are all pillar and no window - all in the name of 'safety'!
1951 Split Window Beetle - SOLD! 1965 Mercedes 230SL 1966 VW Beetle 1968 Mercedes 280SE
1972 VW 412LE Variant - SOLD! err.... 2004 Toyota Corolla
May 29, 2007 10:06:33 GMT
if you like the magazine ad - what about the TV version, with John Hurt?
or the Taunus version?
Last Edit: May 29, 2007 10:12:48 GMT by Autofive
May 29, 2007 10:18:18 GMT
talking of which theres apparently some government review going on into A pillar design as thick pillars on modern cars are reckoned by some research to account for some percent of all accidents at junctions becauseof the blind spot they create.
