v8ian
Dec 24, 2014 14:34:18 GMT
Probably a simple question, I'm looking for a small discrete crank sensor, one that hopefully I can hide from view, so, smaller the better, any suggestions??
tim124
Dec 24, 2014 18:05:31 GMT
Last Edit: Dec 24, 2014 18:07:38 GMT by tim124
Dec 24, 2014 18:15:07 GMT
Maybe look at motorbike items as they are generally smaller than car items
Last Edit: Dec 24, 2014 18:15:41 GMT by redratbike
Dec 24, 2014 18:22:44 GMT
What about the other end of the crank - inside the bellhousing ?
v8ian
Dec 24, 2014 18:44:32 GMT
I want to run a 36-1 wheel and NODIZ, I have a strange feeling that a hall sensor wont work,
Dec 24, 2014 18:50:32 GMT
I guess the engine in question never used a crank sensor ever?
pug sensors are fairly small, especially later ones without a fly lead, not that ive ever noticed much of a difference in sizes.
v8ian
Dec 24, 2014 21:01:12 GMT
I guess the engine in question never used a crank sensor ever? pug sensors are fairly small, especially later ones without a fly lead, not that ive ever noticed much of a difference in sizes. The engine later engine I believe has a suitable flywheel but it doesn't fit inside my bell housing, I'm thinking of putting a stepped wheel on the timing belt pulley and use it as the belt keep,
v8ian
I have done a bit more research, its a 2 wire VR type sensor that I need, not a Hall effect.
Dec 26, 2014 11:11:00 GMT
Ive got a 36-1 wheel that you could fit to the crank pulley and a ford sensor, also a chopped down dizzy if its a pinto your using
Sent from my GT-I9505 using proboards
v8ian
Dec 27, 2014 15:45:32 GMT
Thanks for the offer, I have a toothed wheel, and the engine is a Toyota4age, Still looking, but, something crossed my mind this morning, ---- would a 2 wire anti lock brake sensor work, they are VR sensors too.
