Dec 10, 2014 13:03:15 GMT
Over the winter I am going to rebuild the front suspension on the Monza, One question I have is what paint should I use to repaint the coils after they have been in the blasting cabinet, I ask this as I assume that it has to be flexible.
barty
Dec 10, 2014 13:51:41 GMT
powder coat? i know it will have to go in the oven but i wouldnt think the heat would affect the springs
Dec 10, 2014 14:43:35 GMT
Yeah I'd thought of powder coating, but trying to keep cost down and I'd like to do it all myself if I can, but if that's the best way, then powder coating it will have to be
Last Edit: Dec 10, 2014 15:12:49 GMT by Vintage75
shin2chin
Dec 10, 2014 17:27:45 GMT
I used plastikote on mine and they are holding up well.
I too, would think something a long the lines of plasticote. Rubberized paint should handle that fine, just give them a solid coating. Easy to touch up in any case.
Dez
Club RR Member Number: 34
Painting coil springsDez
@dez
Club Retro Rides Member 34
Dec 11, 2014 10:02:43 GMT
any normal non-catalysed paint will be fine. i prefer POR-15 myself. painted straight onto a blasted finish, it will never come off.
powdercoat is the worst finish you could use, it will crack and flake off pretty quickly, as it never truly sticks to the underlying metal, its more of a 'shell' coating.
Dec 11, 2014 11:19:43 GMT
A mate's springs on his defender have been powder coated. About 4 years later they're still perfect.
Dec 12, 2014 18:24:55 GMT
Thanks for the replies, After doing a google for POR-15 it looks to be very similar stuff to RUST-OLEUM, and that stuff I can get from a local workshop supply shop so I think I'll give that a try.
