Hirst
This avatar is inaccurate, I've never shaved that closely
May 25, 2007 19:04:16 GMT
This will seem like an incredibly amateurish question but I'm surprised that I can't find a good answer online so I'll leave it up to you lot to point me in the right direction. I have now fitted the new wheels to my Charmant, they're 14" with 185/55 tyres. The car is 870kg. What tyre pressure should I be running as a starting point? Thanks!
Alain
Dance monkey boy, dance!
May 25, 2007 19:09:41 GMT
I'd say 28 PSI and see how they look...
'74 Type 181 - Undergoing 'resto' (albeit friggin' slowly! 2 years and counting...) Wedge Panel Van GTi (Still needs finishing) '85 Passat GL5 Estate (Now Breaking) '87 Passat GLS5 Estate (Daily Hack)
Hirst
May 25, 2007 20:24:44 GMT
GOOD WORK!
Works a treat.
Standard pressures are a great starting point,then move them up or down to suit your driving style,average speed,type of road mainly driven on etc etc
May 26, 2007 15:07:10 GMT
In theory the pressures shouldnt be any different, if you pump the tyre up to the standard pressures there`ll still be a different amount of air inside due to the change in volume.
A grown-up had to point this out to me, I used to think Fronteras needed like 80 psi in their tyres to fill them up. Luckily this was before I became a used car dealer.
If I cant get proper data I go by 28 front 26 rear for most things.
sparko
May 26, 2007 17:44:24 GMT
What about on stretched tires? havent got them it just popped into my head
May 26, 2007 23:02:29 GMT
What about on stretched tires? havent got them it just popped into my head Standard pressures.
Dez
Club RR Member Number: 34
May 26, 2007 23:14:46 GMT
not necessarily true if youre fitting wider/skinnier tyres though.
wider tyres generally need a couple of PSI less if you want em to grip in the wet.
May 26, 2007 23:23:57 GMT
not necessarily true if youre fitting wider/skinnier tyres though. What makes you say that? The cars weight doesn't change,so the air pressure that's needed to hold it up doesn't either.....you may need to adjust a couple of psi either way like i said earlier to compensate for the stiffer sidewalls of lower profile tyres,but standard pressures are an excellent starting point and very often correct. I'm not sure what the significance of wet weather is either.....i've never heard of letting any psi out of your tyres when raining.Where did you get this info?
John
May 27, 2007 12:38:00 GMT
If you want to really fine tune your tyre pressures you need a temp gauge so you can measure the runner temps. It needs to be a spike so you can get 10mm into the tread.
I drove down a duel carriageway for 10 or so miles and stopped in a layby and measured the outer inner and middle temps. The average of the outer and inner should equal the middle.
If the middle is hot then its over inflated.
May 27, 2007 13:10:40 GMT
The average of the outer and inner should equal the middle. I guess that calculation is to compensate for a hot inner edge due to -ve camber?
John
May 27, 2007 17:18:18 GMT
The average of the outer and inner should equal the middle. I guess that calculation is to compensate for a hot inner edge due to -ve camber? Yes.
Rob
You know, for kids!
If you want to really fine tune your tyre pressures you need a temp gauge so you can measure the runner temps. It needs to be a spike so you can get 10mm into the tread. I drove down a duel carriageway for 10 or so miles and stopped in a layby and measured the outer inner and middle temps. The average of the outer and inner should equal the middle. If the middle is hot then its over inflated. seems 100% logical - mind boggling to a 'i'll see where they wear' person like me ...
bstardchild
Club RR Member Number: 71
May 28, 2007 10:44:55 GMT
If you want to really fine tune your tyre pressures you need a temp gauge so you can measure the runner temps. It needs to be a spike so you can get 10mm into the tread. I drove down a duel carriageway for 10 or so miles and stopped in a layby and measured the outer inner and middle temps. The average of the outer and inner should equal the middle. If the middle is hot then its over inflated. seems 100% logical - mind boggling to a 'i'll see where they wear' person like me ... I can agree with that All I've ever done is checked the tyres really often and assessed the wear rate accross the tyre over a short period and then adjusted the pressures till I've been happy Not unusual to find pressure changes of up to 5psi required on different makes of the same size tyre On a Senny 205/65 15 with uniroyal 540's I had to run slightly above manufactures pressures (I think due to soft side walls) with pirelli's I had to go down a couple psi
On a number of cars I've had the manufacturer recommends different tyre pressure for different sized tyre options. Only by a couple of PSI mind but still...
