Smiler
Nov 28, 2014 20:22:14 GMT
1979 Reliant Scimitar SE6A GTE 3.0ltr Omega Conversion Another Scimitar, this time the bigger SE6A. The earlier SE5 was the sports car version. Reliant later enlarged the car turning its focus to Grand Tourer. The basic chassis layout was the same but it had increased wheelbase and a larger body. Apparently they were aiming for a more executive area of the market. This particular example (in special order black) started life as an auto. But then a good friend of mine got hold of it. He bought an ex-police motorway patrol 3.0ltr Vauxhall Omega and swapped the engine and gearbox across into the Scimitar. So the car now has a much lighter engine and transmission (the Essex is referred to as a boat anchor for good reason), much better fuel economy thanks to modern engine management, a 5-speed manual gearbox and, according to book figures for the Omega, over 200bhp! This conversion was documented on the Scimweb forum and was the catalyst that spawned a number of such conversions that have since been carried out to both SE6 & SE5 models. The car has been off the road for four years now whilst other modification work was started but due to changing circumstances and interests the work slowed down to a stop and the car was moved to the back of his garden. He decided that rather than leave it to deteriorate any further it would be better to find it a new home and raise some funds towards his new interests (still vehicle/engineering based). So here she is on arrival at the motorclub premises at work, parked next to my SE5. Initial Assessment The exterior finish of the car is cosmetically 'challenged', lots of crazing and stress cracks. But no rust! The car is letting in water through the glass sun-roof and rear tailgate. There may be more leaks but the first two are letting in so much water it's hard to tell. As a result, the seats and carpets are scrap. Fortunately, included in the sale was a good used leather interior so hopefully all I'll need to buy is carpets. The car also sports a custom dashboard as can be seen in the photos below. The original dashboard and centre console came with the car but the centre console that runs along the top of the transmission tunnel is in poor condition. Other faults on the initial 'to do' list are: Passenger door won't open Tailgate hinges partialy siezed Off-side exhaust hangars broken (exhaust drooping) Brake pipe burst so no brakes (replacement in the post) Suspect dirt contamination in fuel tank (as advised by previous owner) Engine management light on Cam-belt due change I haven't checked the electrics yet but as can be seen, there's a fair amount of tidying to do. This is in no way a criticism on the previous owner, after all it was a work in progress. Smiler.
Last Edit: Nov 28, 2014 20:28:17 GMT by Smiler
Smiler
Nov 28, 2014 20:26:27 GMT
Week 1 The first task, after emptying all the parts from the boot (the above photos were taken after this), was to start lubricating all the accessable hinges with penetrating oil and try to release the passenger door.After a bit of coaxing the passenger door is now open, though the tailgate hinges will need a bit more work. I will at some point in the near future gain better access to all the nige points and lubricate them properly. I shall also remove the door cards (for cleaning) and lubricate the door latch and window mechanisms. The new centre console and heater unit has been removed to give full access to the wiring loom. The console came to far into the cabin and on selecting 1st, 3rd and 5th gears the gear knob actually touched it. The heater unit hidden behind is from a Vauxhall Corsa and the previous owner admitted that he got his measurements slightly wrong when he fitted it. He did however include a partially constructed replacement heater box from stainless steel that was intended to replace the original. The reason for the change is that the fitment of the replacement engine required the heater area of the bulkhead to be moved back in towards the cabin. That leaves a lot of wires!
Last Edit: Nov 28, 2014 21:37:55 GMT by Smiler
Nov 28, 2014 23:54:19 GMT
That little lot should keep you occupied for a day or two!
Smiler
Nov 29, 2014 21:48:41 GMT
Yeah, though I'm supposed to be sorting the Escort ready for sale first. Though saying that I am about to sort the electrics on that too (2.0ltr Zetec conversion) so I'll have some practice.
Smiler
Week 2 A recent acquisition of high quality sealant has prompted me to turn my attention to the shower assembly that is masquerading as a sunroof. To this effect the glass panel has been removed followed by the frame itself leaving a big gaping and slightly flappy hole. The replacement brake pipe also appeared and has been duly fitted. The brakes have been provisionally bled and I now have a firm brake pedal but I haven't tested them yet. The priority now though is to get the sunroof hole and frame cleaned up to allow it to be refitted with fresh sealant. Smiler.
Smiler
Dec 12, 2014 23:13:10 GMT
Week 3 The main push is still on the sunroof. The sealant has all been removed from the body shell. This has highlighted all the stress cracks around the aperture. If this car is ever going to win any concourse competitions then these all need addressing before I glue the sunroof frame back in place. I'm not keen on aiming for concourse but I'd like the car to look presentable. Oh what to do... In the mean time, the frame has been getting cleaned up ready for paint. The sealant is proving quite stubborn and tiresome to remove. The rubber seal for the glass is simply bonded in place and does not look to be anything too special so I shall try to find a suitable replacement first rather than just gluing the glass panel shut. Previous sealing attempts have resulted in more cleaning!
Dec 17, 2014 22:27:01 GMT
for the cracks you could use plastic padding gelcoat filler?
Smiler
Dec 18, 2014 10:58:35 GMT
Ooh, I haven't heard of that stuff. Have you had any experience of it? It would be good to know now before I glue the sunroof frame back in as it will affect which sealant I use (one of them is a high adhesion type which will mean that the frame is garunteed to never leak again but also won't ever come of again without taking the fibreglass with it!).
village
Always carries a toolbox. Because Volkswagen.......
Dec 18, 2014 17:13:47 GMT
I take it that this is the self same Scimitar from the (late lamented) PPC forum?
If so, it's good to see it's still in one piece.
"The White Van is strong with this one...."
Chris "Chesney" Allen 1976-2005 RIP
Dec 18, 2014 17:21:16 GMT
Popcorn at the ready.
Smiler
Dec 18, 2014 21:33:48 GMT
I think a few Scimitars have now graced that forum. This car was originaly built for the 2009 PPC £999 challenge and was featured in the magazine shortly after.
The car should be coming home on Monday ready for Christmas. Which means I've got a busy saturday ahead of me trying to get the Escorts roof water-tight so that I can refit the interior.
Dec 18, 2014 21:48:37 GMT
I use plastic padding gel coat filler on my boat. It's meant for grp so ideal for your issues. They look more like screwdriver gouges where someone has prized it off previously. Anyhow work sparingly with the gelcoat repair. It's harder than filler You get it from chandlers. Cheers jed
Smiler
Dec 18, 2014 22:09:44 GMT
Thanks for that, that's good to know.
Those marks are stress cracks in the gel coat from flexing of the roof caused by years of opening and closing the sunroof.
