Bought this to possibly mount in the range rover but need one suitable for vertical mounting. this tank & valve is from a rover 75 estate, fitted at the factory into the spare wheel well. was removed from the car as the front end system had failed. Pics to follow
£25 collection only from Birmingham or Warwick
Cheers Matt
Nov 20, 2014 20:03:41 GMT
You can mod the pick up pipe.....
Koos
Nov 20, 2014 21:13:35 GMT
You can mod the pick up pipe..... Not if you want the 80% fill cut off to work - the multivalve will be in the wrong place. Its probably worth posting up the test date on the tank too
i've got a 100L cylinder tank now for the rangey, so decided to move this on as its taking up space...must get photos....
Height, Width, Depth? Could be interested for a Passat B5
Height, Width, Depth? Could be interested for a Passat B5 Its an ICOM f86 67 litre tank, which the manufaxctuer states is 630mm x 270mm cheers Matt
I may also sell a 100l stako cylinder tank half full of gas as i'm picking up a 97l doughnut tank.
Any chance of getting it shipped, or are you 100% collection only? Brum is a hell of a trek!
It would require a pallet as these tanks are rather heavy, so collection only TBH or RR pony express
