May 23, 2007 19:43:40 GMT
I have a home-brewed electric fan set-up on my Merc, which uses a thermoswitch from an OHV Escort. However, it kicks in a little bit hot for my liking and was thinking about alternatives. I know Kenlowe kits have an adjustable thermoswitch, but at £50 it's about double what I spent on the whole set-up! Are there any other options? Can I modify a standard thermo switch in some way? Or do they make the switches in various temperature settings (maybe for hotter / colder climates)?
bstardchild
Club RR Member Number: 71
May 23, 2007 20:11:28 GMT
Or do they make the switches in various temperature settings (maybe for hotter / colder climates)? Yep - when I first put the Monza back on the road with a 24V lump it ran a lot hotter (too much in traffic) I took the old Electric fan switch down to my local motor factors and said need a cooler one - 3 mins rummaging and bingo one that cut in 5 deg earlier and problem solved
May 23, 2007 20:20:26 GMT
Ooh, cheers BC! I shall give my local factors a go.
May 23, 2007 20:23:02 GMT
I've always used an adjustable controler from SVC. scroll down in this linknot completely budget I know, but at £24 its cheaper than £50 one you found. like BC says, try the 'factors first for a different temp switch.
Dez
Club RR Member Number: 34
May 23, 2007 20:30:52 GMT
i use the same as B+D.
available for about £20 all in off egay, its some landrover guy sells em.
madmog
Club RR Member Number: 46
May 24, 2007 17:10:11 GMT
Thank God I found it, a few years ago I had the same problem and surfed around and eventually found this link www.suzukiclubuk.com/elecfan.htmlWhich indirectly leads to this site uk.farnell.com Where you search for 560250 which costs £12.86 (plus vat and postage.) Been fitted for a few years in my car and working nicely. Cheap enough to be worth it.
May 24, 2007 17:59:16 GMT
cheers madmog, i needs one too, mines on a flick switch on the dash and its a pian in the keeping an eye on it in traffic, although i must admit the car behaves itself miles better temp wise since the new engine went in. hardly need the fan at all in normal driving.
"quote hairnet"
I'm not paying nine pound for a pi$$!
[/quote]
