1986 ford capri laser fully running project
ill get some better pictures tomorrow
moted till april 7th 2015
no tax
114k
it is registered as a 1.6 but has a 2.0 205 pinto fitted with very good compression no knocks rattles or bangs from it
fitted with the 32/36 carb with manual choke this looks to have been refurbished recently both flaps open as they should
she has a chrome k&n air filter fitted
I have a new fuel filter to go on
ive fitted it with new-
dizzy cap
points
condenser
points
spark plugs
ht leads
cam belt
head gasket
inlet gasket
exhaust gaskets
fan belt
she fire up and sounds well
fitted with a four branch manifold
five speed type 9 gearbox
she starts and drives well
the front brakes are a little rusty as its been stood a couple of months but will clean off with a run
its been de bumpered along with the side strips removed
they have removed the sunroof and welded a replacement panel in with a brace underneath the roof is pretty dam strong
I'm assuming they were going for the track day look possibly a roll cage etc
the strut tops are untouched and good the doors and boot are good
one key fits all locks
the petrol flap is with the car
it wants a non sunroof roof lining which are avalible on here unless your going to fit a roll cag
all the repairs have been done and finished in high build primer on the sections it can be used as is or start prepping for paint
underneath is very very good with no work needed
I have the full v5 in my name
its not a bad project for someone looking to get on the capri ladder
it has a brand new battery too
viewings are more than welcome test drives are limited to the yard as it has no screen fitted
any questions feel free to ask
no tax
114k
dizzy cap
points
condenser
points
spark plugs
ht leads
cam belt
head gasket
inlet gasket
exhaust gaskets
fan belt
