Ford Sierra P100 Pick-up 1990 H Registered , First Registered in the UK 10.08.2007 so one owner on the V5 , was registered and/or used elsewhere in the UK and declared manufactured 1990 , was previously owned and used on the Isle of Man by the Isle of Man Fisheries Board , doesn't have a current M.O.T but I have it booked in for Friday 14.11.2014 so all being well it should have 12 months M.O.T.I originally bought it to restore back to original as it is originally yellow and I hadn't seen many this colour and is reasonably straight . It did need welding in some places which I have had done to a professional standard but that is as far as I have done due to an ever increasing workload , family and of course other projects on the go so thought I would try it on here and see what happens.
Good Points ; Originally Yellow which is a rare colour for one of these (last owner resprayed it a matt blue)
One owner on the V5
Will come with 12 months M.O.T
Very Original
Not so good Points ;Ideally needs a respray
Heater blower is a bit temperamental
Rear tub needs a little tidying
Could do with a replacement tailboard
Front half of the carpet is missing
The mileage is showing around 27k but assume its 122k (although you would question it after looking in the engine bay) , it starts , drives and stops , all tyres are good , everything works apart from the heater blower which sometimes does and other times doesn't , the front carpet is missing as I have misplaced it when the interior was removed for the welding (am trying to find it so if it turns up I will amend). If you need to ask anything else or want to come and view it which I hope anyone interested would then please give me a call on 07974 699555 at any reasonable hour. This is a solid p100 and in my opinion deserves to be put back to original even for the colour alone because you just don't see them anywhere (in that colour).
One owner on the V5
Very Original
