Nov 10, 2014 19:36:35 GMT
Has anyone got a set ready for le bin? I need a set of aluminium top hats for the front springs. Mine didnt come with so went straight into the top mounts, which means that my steering is rather sticky and loud due to the spring turning instead of the bearing in the top mount.
The coilovers are mk2/3 golf but I think all of the cheap coilovers that use top hats have all the same ones, so let me know if you have.
Dez
Club RR Member Number: 34
Nov 10, 2014 19:49:52 GMT
i will have some. probably FK. will look tomorrow.
Nov 10, 2014 20:50:29 GMT
i will have some. probably FK. will look tomorrow. Awesome. I think all the cheaper coilovers use the same kit. Let me know when you do
Nov 21, 2014 18:40:34 GMT
I have some that lower the car about 20mm so you can have more shock travel for the same amount of ride height? Think they're new, unsure of make but they're of decent quality.
'73 3.0CS '81 Golf Gti 1.6 '83 Golf 20VT '87 M535i '86 Escort RS Turbo
Nov 27, 2014 21:19:54 GMT
I have some that lower the car about 20mm so you can have more shock travel for the same amount of ride height? Think they're new, unsure of make but they're of decent quality. I have bought a pair from Dez, which are yet to turn up. Will PM you if I don't get them.
