This is part of a home brewed hydraulic clutch setup on my GTM Rossa, the box (Rover R65) was originally a cable setup. It all works reasonably well but I'd like to be able to replace/repair when needed and also find a cap for it to keep the water out of the bore, it's rusted enough as it is..
The overall length is 92mm, the mounting holes are approx 60mm CTC and the bore is approx 22mm. The only markings are 'E09' and the pipe fittings are M12x1.
Any suggestions gratefully received.
