Oct 28, 2014 19:45:58 GMT
i need a custom clutch hose
does anyone on here make them or reccomend someone that does , or a site that does the bits for a ok price
as far as i know i want -3 hose pref with the heatshrink over it , m12 x1 banjo ends
Midas
Club RR Member Number: 14
Oct 28, 2014 19:51:29 GMT
Earls have a custom hose maker feature on their site, I suspect you may struggle for the M12 banjo though.. I'm in the same position.
Oct 28, 2014 19:52:13 GMT
www.torques.co.uk, Alex and his guys are very knowledgeable, drop them an email or a call and they'll sort you out.
Oct 28, 2014 19:52:46 GMT
yeah did look on there
hel can do it but its £38 which i thought was dear
Oct 28, 2014 19:58:28 GMT
Last Edit: Oct 28, 2014 19:59:02 GMT by welshpug
Oct 28, 2014 19:59:55 GMT
I'd say £38 was quite reasonable.
Oct 28, 2014 20:07:15 GMT
I'd say £38 was quite reasonable. Agreed that is very cost effective........
phil1380
East Midlands
Only the depth varies........
Oct 30, 2014 10:58:17 GMT
Try Pirtek.
They are pretty much Uk wide, and do all types of hose from small stuff to industrial machinery. M12 shouldn't be a problem.
Phil.
Oct 30, 2014 13:16:11 GMT
I wouldn't, they're the most expensive ones out there!
Oct 30, 2014 13:30:24 GMT
Rally design do banjo bolts, braided hose and banjo fittings, I would call them to make sure they match the bolts to banjo, and hose to banjo, but it should cost around £25 at worst if you had to use dash4 and a bit less in dash3 if the banjos are suitable www.rallydesign.co.uk/index.php?cPath=562_85_248_249&&page=3Brian
Iain
Oct 30, 2014 15:56:58 GMT
I've used all RallyDesign unions and pipework, all seems fine but it's bare braid rather than plastic over the top which is possibly not what you want? That said mine's been fine inside and out the car for years.
Dead easy to make your own lines, I've never had one leak even the first one I did ever from a guide followed on the net.
Oct 30, 2014 18:53:53 GMT
I put heat shrink over the hose before making the last joint, you have to cut the heat shrink over length and compress it while fitting the union, then be careful when shrinking so as not to overheat the plastic tube in the process.
Think Automotive in Isleworth, they make a lot of the stuff that others sell, they're always easy to order from & speedy delivery.
