Oct 22, 2014 14:18:49 GMT
i have a car with a hydraulic clutch , the clutch still drags slightly until the very bottom of the pedal travel which isnt ideal
now how do i diagnose whats up , i have bled the system various ways and its know to be alkward , but could it be a failing master cyl or slave if so how do i diagnose which is faultly
help with hyd clutch diagnosisChasR
@chasr
Club Retro Rides Member 170
Oct 22, 2014 17:26:06 GMT
In most cars it tends to be the slave which is faulty, but before you go replacing both of them I would check the following: - Is there any dampness present at either the slave cylinder or master cylinder
- What kind of pipe connects the two? Is it a solid steel pipe or a rubber flexi - If the latter that may also cause issues (breaking internally)
- How did you bleed it? Some slave cylinders need to be fully compressed in order to bleed effectively (Triumph ones often require this)
Oct 22, 2014 17:57:20 GMT
no obvious dampness
its a part steel part flexi
i bled it as is ..so youre saying take off the slave and clamp it so the piston is fully in?
Oct 22, 2014 18:39:12 GMT
Flexi ballooning when under pressure or slave cylinder.
@chasr
no obvious dampness its a part steel part flexi i bled it as is ..so youre saying take off the slave and clamp it so the piston is fully in? Precisely .
bortaf
Oct 23, 2014 12:53:25 GMT
Is the slave cylinder internal or external on this secret car ?? if it's internal clamping it shut will be awfully difficult but i guess by your answer that this secret car has an exteranl slave ?? If this secret car was say a transit it's a well know problem and they really need reverse bleeding, is it a transit ?? If it is a citroen, they are very prone to leaking if they new slave wasn't supplyed with a new seal for the end of the pipe, even from citroen some kits don't have the seal some do, is it a citroen ?? Fiesta are know for pedal problems, civic are a PITA to bleed, on some cars i remove the slave, zip tie it shut and hold it above the master to bleed them, some i don't.
Last Edit: Oct 23, 2014 12:53:49 GMT by bortaf
R.I.P photobucket
Oct 23, 2014 14:01:12 GMT
none of the above lol ..yes its external
@chasr
Oct 23, 2014 20:01:21 GMT
So what it is? It can take a hell of a lot of guesswork out and you may get more responses to boot.
Oct 23, 2014 20:35:24 GMT
mk2 golf g60
