MR TIKI
TIKI,style from a different angle!
May 19, 2007 21:55:51 GMT
Fiat500 Next step: July, the 4 - the new Fiat 500 official launch date. ... 500x500 online booking, the new Fiat 500 advance booking dedicated to . ... www.fiat500 ;D ;D ;D ;D ;D ;D WANT,WANT AND WANT IN THAT ORDER!
Boldly driving faster than a tin worm can wiggle.
May 19, 2007 21:59:39 GMT
Retro or not, I think they are damned cool.
The first new car for a while that I'm looking forward to seeing in the flesh.
May 19, 2007 22:07:47 GMT
no no no, this is the new fiat 500 (cant find any pictures, but its a ducati 999 powered carbon copy of the oiriginal version!)-
F500 - SPECIFICATIONS
BODYWORK Exterior - Carbonfibre panels suspended on chassis tub; Ferrari Rosso Corse red paintwork; Interior - Painted & natural carbon dash, crema leather door-cards
CHASSIS Chassis tub - Folded & bonded carbon skins over 1” aluminium honeycomb – composite monocoque, aluminium hard points; Roll-over structure - Full FIA specification cage in chromoly tube; Crumple zone - Front mounted composite energy absorption structure
DRIVER ENVIRONMENT Pedalbox - Bespoke billet CNC machined aluminium pedalbox; Gearchange - Sequential H-pattern – chrome gearlever gate; Dash - Re-trimmed Ducati clocks; Steering wheel - Fiat 500 mounted onto quick release boss & collapsible column; Seat - Carbonfibre seats trimmed in crema leather; Harness - Six point Sabelt racing harness
WHEELS, HUBS, UPRIGHTS, BRAKES & STEERING Wheels - 13” split rims in aluminium or magnesium with centre lock mounting; Hubs & uprights - Bespoke billet CNC machined in aerospace grade aluminium; Brakes - Brembo four pot alloy callipers on Brembo Composite Ceramic discs; Steering rack - Motorsport aluminium quick rack – 1¼ turn
SUSPENSION Wishbone - Independent aero-section asymmetric double wishbones; Springs / dampers - Push rod activated, inboard Nitron three way adjustable spring dampers; Setup - Fully adjustable corner-weights, camber, castor, toe & ride height; Bearings - Aerospace grade spherical and rod end bearings
TRANSMISSION Gearbox - Six speed sequential; Ratios - 1st 37/15, 2nd 30/17, 3rd 28/20, 4th 26/22, 5th 24/23, 6th 23/24; Primary drive - Straight cut gears; ratio 1.84; Final drive - quaife differential with integral reverse gear; Clutch - Dry multiplate with hydraulic control; Gearchange - Chrome H-pattern gate, twin cable operated; Driveshafts - Splined with lightweight motorsport tripoid joints
ENGINE Type - Ducati 999R. L-Twin, 8 valve Testastretta Desmodromic; liquid cooled; Displacement - 999cc; Bore & stroke - 104 x 58.8mm; Compression ratio - 12.5:1; Power - 110kw – 150hp @ 9750rpm (200hp WSB spec. available); Torque - 11.9kgm @ 8000rpm; Fuel injection - Marelli electronic fuel injection, 54mm throttle body; Exhaust - Single carbon muffler with catalytic converter; Emissions - Euro 2; Lubricants - Shell Advance
PERFORMANCE 0-60mph - Sub 4 sec (estimate); Top speed - 120mph (limited); Power to weight - 428bhp / tonne standard. (up to 600bhp / tonne available); Weight distribution (%) - 53R : 47F
I'll take one of EACH type THANKYOU!
Remade In Australia thereimaginarium.com.au
May 20, 2007 10:37:16 GMT
Nice bit of CGI work
street
6.2 ft/lbs of talk
May 20, 2007 10:40:28 GMT
no no no, this is the new fiat 500 (cant find any pictures, but its a ducati 999 powered carbon copy of the oiriginal version!)- F500 - SPECIFICATIONS BODYWORK Exterior - Carbonfibre panels suspended on chassis tub; Ferrari Rosso Corse red paintwork; Interior - Painted & natural carbon dash, crema leather door-cards CHASSIS Chassis tub - Folded & bonded carbon skins over 1” aluminium honeycomb – composite monocoque, aluminium hard points; Roll-over structure - Full FIA specification cage in chromoly tube; Crumple zone - Front mounted composite energy absorption structure DRIVER ENVIRONMENT Pedalbox - Bespoke billet CNC machined aluminium pedalbox; Gearchange - Sequential H-pattern – chrome gearlever gate; Dash - Re-trimmed Ducati clocks; 47F...... and so on.... Wowser! Who's making this?!?!?! Sounds fapping excellent!
May 20, 2007 11:02:08 GMT
Those photos look like those bloody awful pottery 'car caricatures' that you usually see someone floggin to barries at car shows, with massive wheels etc etc.
