Lowrider plans...stealthstylz
@stealthstylz
Club Retro Rides Member 174
May 18, 2007 19:11:30 GMT
Another way would be to remove the front suspension. You could then modify the chassis by installing a C section above the original rail, then cutting part of the original rails away. This would allow you to mount something like a cortina IFS high in the car to lower it. Hydraulics would be much easier to fit then.
Matt
Strutted cars can be made to move, bagged cars can be made to move. If it were me with your base car I would do it thus- rims- astro supremes or 13" wires, no question, tucking a stretched tyre into the wheelwell rocks. Keep em clean or get powdercoated parts. the main rust areas on wires are spokes, unless you get daytons and they run stainless. If you want to sit on the deck then strut bag the front, deleaf the rear and run a bag on top of your axle with internal bump stops. Slam Specialies bags are to go for. As for your system, engine driven compressor, 1/2" valves and 2 x 5 gallon tanks. Just my 2p... If you want crazy moves, buy a different car. Like i said before, crazy moves isnt the plan. its the bagging and the styleing is the plan. Bagg, engine, paint, rim, ride. your way seems much less drastic than everyone elses IMO
Your car is not 'epic', this thread is not 'epic'....the OCEAN is epic, the UNIVERSE is epic.... please stop misusing this word!! It would appear Hotrods are the new VWs - aint fashion funny! '69 BUICK LESABRE 350
Ether
2.5k wouldn't get you kandy paint. Not unless you did a lot of the prep yourself.
Please don't get rod/Foose wheels, the car wouldn't be a lowrider with them on. As Tom says, Supremes or wires.
Ether
Oh, and traditional wires are 13in, not 14in.
i didnt really plan on Kandy paint ....maybe on some detail but not all over. I'm still drawing paint designs on everything lying around so thats not nearly decided yet LOL
phatphord
Scorpilow
May 19, 2007 10:53:53 GMT
If you wanna chat about bagging stuff mate pm me and I'll give you my number.
1994 Ford Scorpio Lowrider um...and some bikes...
May 19, 2007 11:23:17 GMT
cheers man Can you still make a car lay on the tarmac with bags? its not lift I really want from it...its the ultimate low! I guess the size of the wheels would play a big part in it
phatphord
Scorpilow
May 19, 2007 19:16:48 GMT
My scorpio hits its monocoque on the floor on full drop. I have 10mm under my front crossmember...stuff scrapes when I drive it that low. Hydros and bags do the same thing- they lift the car from its lowered position. They don't lower it. Get your car on the floor and then use either method to lift it.
Dez
Club RR Member Number: 34
Lowrider plans...Dez
@dez
Club Retro Rides Member 34
May 19, 2007 19:36:17 GMT
Hydros and bags do the same thing- they lift the car from its lowered position. They don't lower it. Get your car on the floor and then use either method to lift it. and thats what 90% of people fail to realise when it comes to bags/juice. johnny, as has been said, you can bag the struts. but i see it as a bit pointless when youve got to rip the whole rear end apart to get rid of the leaves, its hardly like youre doing it for ease of fitment or anything. if youre going to that much trouble at the rear, you may as well swop the front suspension out to something more suited.
May 19, 2007 21:15:55 GMT
well if thats what needs to be done then it shall be done like i said, its not a money issue or time as its gonna be gradual as i like...this car is gonna be a keeper when its done
May 19, 2007 23:17:38 GMT
I on the other hand applaud a dedication to excellence woot - then you'll be part of the "scene"
Ether
Lol @ ^ In other news, I think your idea is rad. It would be cool to see an IRS conversion from leaves done. Especially on the Brit equivalent to an Impala. Good luck with it, I say
MaxN
Last Edit: May 20, 2007 5:30:25 GMT by MaxN
Lol @ ^ In other news, I think your idea is rad. It would be cool to see an IRS conversion from leaves done. Especially on the Brit equivalent to an Impala. Good luck with it, I say Cheers.....good to know everyones not so pessimistic about it all. I'm gonna have a chat to the guys at DS Engineering next week, see what they say about it all. Anyways, as per the ORIGINAL question.... I think I'm gonna have to roll on some Supremes ive been scouring google images and they do just look great!
Anyway.....i know you lot love a photoshop challenge...... Anyone fancy suggesting some paint?...
Ether
May 20, 2007 10:43:35 GMT
Kandy dollar-bill green, or white with pink patterns? Then you could leave the white base (which might save time repainting the awkward bits) Are you gonna go super trad and fit sidepipes with guitar strings taped on the end?
Ether
May 20, 2007 10:46:41 GMT
May 20, 2007 11:00:47 GMT
Kandy dollar-bill green, or white with pink patterns? Then you could leave the white base (which might save time repainting the awkward bits) Are you gonna go super trad and fit sidepipes with guitar strings taped on the end? I only had a couple of ideas about pipes yet.....did get it into my head to have a set of two on each side cut out of the front wings just in front of the door towards the bottom. But that could ruin the lines. Migth just go for some nice Chrome Twin pipes out the back I don't want to go too trad otherwise I might as well just buy an impala or something. there seems to be a good flow of Z6's on the 'Bay at most times so I just gotta find one thats good enough body-wise to snap up!
Ether
May 20, 2007 12:07:59 GMT
Yeah, pipes might be a bit much. Patterns would be rad on a Zeph, though. That said, they do lend themselves to ultra-trad ranfla styling, par exemple:
