barty
Sept 27, 2014 17:27:08 GMT
Can anyone help me with this anoying problem with my freelander, the wipers when turned onto intermittent will not make a full sweep of the screen they will do half a sweep then stop mid screen. They are ok on normal and full speed. Any suggestions ? could it be the motor or maybe the switch or something else ?
Sept 27, 2014 17:51:05 GMT
check the plug to the wiper motor for corrosion
Sept 27, 2014 17:51:42 GMT
Sept 27, 2014 18:15:56 GMT
if the plug is ok on the motor , it may be the park switch on the motor itself.
'88 Cadillac Brougham hearse (white) '91 Carlton GSi 24v '72 Dodge dual cab pick up '99 Mercedes S55 AMG
barty
Sept 28, 2014 13:36:33 GMT
thanks ill check the above and get back to you with the results, if it the park switch what options do i have ?
Sept 28, 2014 14:11:33 GMT
replace the motor, or take it apart and fix it.
taurus
Sept 28, 2014 20:19:32 GMT
I don't know the wiring on the Freelander, but last time I had that problem it turned out to be the permanent live feed to the wiper motor had failed. It depends how it's wired - some have two live feeds to the motor, a live from the wiper switch and a permanent live that keeps the feeds to the motor until the self-park switch activates. On mine it was that second live cable that had fractured.
On intermittent the relay triggers the motor to start, then the current is cut and the motor continues on it's self-park cycle. So it's either the self-park switch or the live feed for the self-parking.
barty
Sept 29, 2014 14:28:15 GMT
thanks to all for your great advise, ill get back to you all if i get to the bottom of it
