Feb 21, 2017 22:18:28 GMT
I think most of us have done the same, if not something similar I wouldn't feel stupid at all.... it's all part of the learning experience!! Things like this stay with you and once it's sorted and clicked in your brain should mean you'll find it easier to set timing in the future (or you'll smash the car to pieces with the distributor ) Keep up the good work
Feb 21, 2017 22:54:52 GMT
^ As above, if it works first time it's easy to accept it without really understanding *how* and *why* it works. We learn (and understand) more if we need to think about a problem to fix it. "me timing the engine on the wrong stroke which is never going to work..." Not a disaster - most folk on here will have done it (me more than once!) Tip : if the drive cog is exactly 180* wrong - as yours was - simply rotate the crank 1 full turn to fix the problem (saves removing the cog and trying to line it up again) Your methodical plan sounds good. My next checks would be make sure the rotor arm is pointing where it should be, and fit 1 plug lead from that point of the cap to plug#1. The firing order tells you where the rest go Keep the faith, and feel free to learn from other folks previous problems & fixes!
vulgalour
Club RR Member Number: 146
Feb 21, 2017 23:35:19 GMT
Nomad, I am so happy you said that! I shall leave it in situ and save myself a lot of faffing Overall I'm feeling better about the whole thing. Cheers for sticking with me on this one everyone, hopefully I'll get an hour or two on it tomorrow.
*community-based motivation achieved
Thinking about it - my "fix" won't cure the problem It will get the distributor right but will also turn the camshaft away from where you want it (from TDC compression stroke to TDC on exhaust stroke) Errm. Oops?
vulgalour
Feb 22, 2017 13:16:03 GMT
No, it does fix it because what I thought was compression is actually exhaust so it sorts out two birds with one stone. Apparently. I'll find out shortly as I'm going out to tinker.
vulgalour
Feb 22, 2017 17:06:42 GMT
Update time! Ready for some frustration? I bet you are. First job is to rotate the flywheel a full revolution to sort the timing out. It's just about impossible to photograph the valves, but this was the before shot (I think). Check the distributor drive cog and find it's back to the same place it was. So that needs to come out and be turned around so the fat side is on the side it should be. Made sure my timing mark was where it should be, like so. Now, the valves are in a different position to previously, but again quite difficult to photograph. Turned the distributor drive cog around so it's aligned properly. This was actually much easier than my first attempt so I guess I'm getting the knack of that. I was asked which distributor is fitted, so here's the details for that. Put the distributor back in and the rotor arm now points in exactly the opposite direction to what it did before giving the flywheel one full revolution. That's to be as expected, from what I understand people telling me. I also put enough pipework in and an improvised bung for the vacuum/fuel thing under the carburettor. This now appears to be working properly as the sellotape cap was deformed inward on the pipe so must be creating at least some vacuum. Distributor cap and leads refitted in the correct order, connected up to the coil, a little petrol down the carb, jump leads to the Rover because I'd forgotten to fully charge the Renault's battery and we tried again. This is where the frustration is because I'm sure you'll want to hear I got it running allbeit badly and much rejoicing was had. What happened instead were a few weak pops in the exhaust rather than backfiring out the carburettor but not enough to get the car to actually run. A little more accelerant was applied to the carb and again we almost got it to fire but there is another problem somewhere. It does appear the timing is as it should be now, so that's something. Even with a remote fuel source we're getting fuel up to the carb but it's not getting through it, I'm guessing there's a blockage in there somewhere. There was some black gunge around some of these holes that were previously clean. I plonked the air box back on because I was fed up of moving it every time I got in the car and decided to do this update to help me troubleshoot the potential problem rather than poking blindly at something I don't understand the cause of. My suspicion is that there's still a blockage in the carburettor somewhere and the spark may be too weak to make use of what fuel is getting through or put directly into the carb. I will agree that it must now be something very simple to find, it's just going to take me a while to figure it out because of my lack of experience with this sort of fault. Please be patient with me. On a happier note, the new dash clock arrived.
Feb 22, 2017 17:44:19 GMT
i know its irrelevant because you have the flywheel timing mark, but when i did my C+G (which was just old enough to be on BMC engines) they just taught us to put your thumb over no.1 spark plug hole as you turn the crank, to feel if its the compression stroke (or not) carb woes, sad face although to pull any fuel in it has to be consuming some air, are the valve clearances ok ?
Last Edit: Feb 22, 2017 17:44:43 GMT by darrenh
Feb 22, 2017 17:50:39 GMT
My routine : Set the crank at TDC (using the flywheel marks - as you have been doing) Check #1 cylinder is on compression stroke (both valved should have clearnace - if one is down then you're not on compression so give crank 1 full turn) check distributor drive cog (as you are...) fit distributor, see where tip of rotor arm is pointing - connect a pluglead from that distributor cap connection to no#1 cylinder. find firning order in the manual gently turn the engine and see which way the rotor arm turns - then connect the rest of the plugleads as per firing order. pub! Shout if any questions and we'll try to help
Feb 22, 2017 19:22:32 GMT
I would set it on the timing marks, then turn the engine back and forwards, the rockers that move on either outer cylinder (1 or 4) is on its exhaust stroke, the rockers that don't move (on either outer cylinder) I would call, for talks sake, number 1. I would then place the lead for this "number 1" cylinder onto the distributor cap where the rotor arm is pointing, then I would turn the engine in the direction of rotation and put the leads on as required (1-3-4-2). Think that should work out ok.
Feb 22, 2017 19:38:59 GMT
My routine : Set the crank at TDC (using the flywheel marks - as you have been doing) Check #1 cylinder is on compression stroke (both valved should have clearnace - if one is down then you're not on compression so give crank 1 full turn) check distributor drive cog (as you are...) fit distributor, see where tip of rotor arm is pointing - connect a pluglead from that distributor cap connection to no#1 cylinder. find firning order in the manual gently turn the engine and see which way the rotor arm turns - then connect the rest of the plugleads as per firing order. pub! Shout if any questions and we'll try to help This ^^^
Feb 22, 2017 21:24:45 GMT
I was going to say put your thumb over the plug hole to check compression stroke.
As my dad taught me, if there's compression, fuel & spark it will run. It may run like *poo* but it will run.
So one of the 3 is missing. If you are using easy start or similar & its still not running (for a few seconds) then you need to double check the timing. If its popping out of the exhaust it sounds like it may be firing when the exhaust valve is open.
vulgalour
Feb 22, 2017 22:02:27 GMT
There's some debate about the distributor drive cog on another forum as to whether it should be perpendicular to the block or at 60 degrees as per my manual. The more I've thought about it tonight, the more the 60 degrees makes less sense because that means the rotor arm sits halfway between two of the plug leads rather than pointing at one when it's at TDC. So, if I rotate the distributor or the cog I should be able to rectify that, I imagine?
I also know fuel isn't getting through the carb but when we put petrol directly in it did nearly run. Perhaps if I'd put more fuel in it then it would have run properly, I dislike playing with petrol and such so I was perhaps a little frugal.
Feb 22, 2017 22:31:43 GMT
if you set the timing marks, then where ever the rotor cap is, is about where that lead should be. So as you've done this, and it's popping inthe exhaust maybe the timing is still out a bit
Can you crank the engine over and then rotate the distributor at the same time, if you rotate it slowly, no more than +/- 45 degrees it should hopefully try to run.... if you get it to run then you know how you need to move the drive cog
Does that make sense?
Feb 22, 2017 23:53:21 GMT
You're overthinking this.
The rotor arm needs to be in line with the lead for no 1 cylinder, not mid-point between two.
When the piston is at the top of its stroke on no1 cylinder, with both valves closed, that's the tdc you're looking for.
Wherever the distributor drive dog is sat doesn't really matter at all - put the distributor in and see where the distributor arm is now pointing. If you can twist the body of the distributor so that one of the leads lines up with the arm, and use that position for no 1 lead, and the rest in order, then the car will run. It might not be tidy, and the vac can might be in an awkward place, but it will run.
If you are (as I would be) determined to get things right, then when you are at TDC with the valves closed on No 1, drop the distributor in and the arm on and see where it's pointing. If it should be at 12 o'clock and it's at 3, then remove distributor, note the position of the drive dog, then remove and reinsert it so that it's rotated the necessary 90 degrees and re-fit the dizzy.
Check which way the distributor is turning too, so that you've got the leads on in the right order.
djefk
You're overthinking this. The rotor arm needs to be in line with the lead for no 1 cylinder, not mid-point between two. When the piston is at the top of its stroke on no1 cylinder, with both valves closed, that's the tdc you're looking for. Wherever the distributor drive dog is sat doesn't really matter at all - put the distributor in and see where the distributor arm is now pointing. If you can twist the body of the distributor so that one of the leads lines up with the arm, and use that position for no 1 lead, and the rest in order, then the car will run. It might not be tidy, and the vac can might be in an awkward place, but it will run. If you are (as I would be) determined to get things right, then when you are at TDC with the valves closed on No 1, drop the distributor in and the arm on and see where it's pointing. If it should be at 12 o'clock and it's at 3, then remove distributor, note the position of the drive dog, then remove and reinsert it so that it's rotated the necessary 90 degrees and re-fit the dizzy. Check which way the distributor is turning too, so that you've got the leads on in the right order. Couldn't put it better myself! Vulg can you report back on this before touching anything else? As blackpopracing has said, you only need compression, a spark and fuel for it to run - However at the risk of stating the obvious, you need a spark at the right time. glenanderson's instructions will eliminate the possibility of spark timing being out, so assuming you're sure the compression is now fine after your efforts in rebuilding the engine, you then have a solid base to troubleshoot why the spark is too weak - the only possible issue left - if the thing still won't run with a dribble of fuel down the carb.
Last Edit: Feb 23, 2017 1:00:39 GMT by djefk
vulgalour
I've *just* finished work for today so I can catch up on forum threads.
Tomorrow, the plan is a simple one: 1 - run a wire/air through the pipework in the carb to make sure it's blockage free 2 - rotate the distributor 45 degrees so the rotor arm points at lead 1 when at TDC on the compression stroke 3 - put it all back together again 4 - turn the key and see what happens
I've had a *lot* of advice, opinions and info thrown at me. A lot of it is exasperation that I can't just Do The Thing, some of it is genuinely useful and some of it is opinion based conjecture that muddies what I'm doing and makes it even harder for me to Do The Thing.
Timing is something of a nemesis for me. It should be such a simple thing and yet I repeatedly manage to cock it up one way or another even with instructions. Anybody would think I couldn't count. If nothing else, it's a good reason for me to only ever own cars with 4 cylinders.
You're overthinking this. The rotor arm needs to be in line with the lead for no 1 cylinder, not mid-point between two. When the piston is at the top of its stroke on no1 cylinder, with both valves closed, that's the tdc you're looking for. Wherever the distributor drive dog is sat doesn't really matter at all - put the distributor in and see where the distributor arm is now pointing. If you can twist the body of the distributor so that one of the leads lines up with the arm, and use that position for no 1 lead, and the rest in order, then the car will run. It might not be tidy, and the vac can might be in an awkward place, but it will run. If you are (as I would be) determined to get things right, then when you are at TDC with the valves closed on No 1, drop the distributor in and the arm on and see where it's pointing. If it should be at 12 o'clock and it's at 3, then remove distributor, note the position of the drive dog, then remove and reinsert it so that it's rotated the necessary 90 degrees and re-fit the dizzy. Check which way the distributor is turning too, so that you've got the leads on in the right order. not as well as that does Good luck tomorrow!!
Having had exactly the same pain years ago with a 1725 Holbay rebuild, I echo the above. Good luck tomorrow! Mind, being towed down the road with no bonnet on by the old feller's Volvo, spitting flames out of a gauze filter was quite spectacular. Just not very effective.
melle
South West
It'll come out in the wash.
It should be such a simple thing and yet I repeatedly manage to cock it up one way or another even with instructions. We've all been there... It's very much like cycling or welding (much more than it is like black magic); no matter how many instructions you get, as long as you don't "get" it, you (think you) keep making a fool of yourself. All of a sudden you'll be there though, and you cannot understand how you've ever not been able to do it. I'm sure you'll get the hang of it one day, practice makes perfect.
