Sept 10, 2014 8:57:29 GMT
I should be picking up a 1993 BMW estate tonight which I plan on breaking to get required parts for mine. The rest will be up for grabs and I want to clear it quite quickly which why I'm posting this now to gather interest. I will start stripping it on the weekend if not before and will upload a few pics but if anyone wants anything specific I can remove and photograph that first. It's a 316 Lux touring 1993 e30 in Sterling Silver with a current MOT Has 15" BBS alloys, not sure about centre caps Drivers door is dented rest of the shell and panels look OK from the pictures Dash is cracked but not sure how bad yet Drivers seat worn in usual place but I think good passenger seat to transfer fabric across, it's grey upholstery with black vinyl surround. It's on coilovers and has a welded diff. Key parts I'm taking for myself: - headlining - drivers side headlight - drivers side taillight - potentially drivers side front wing - fuel tank PM me to express and interest and I'll update you once I've got the car and know more. Located in North Bristol, can post smaller parts. Thanks
Sept 14, 2014 19:27:04 GMT
Does this have a sunroof ? And if so its it manually opened with a handle and if so how much for said handle thanks
Sept 14, 2014 22:35:03 GMT
Hi, I need a fuel pump and possibly nearside wing if straight and rust free.
1995 Range Rover 4.0 1995 BMW 320i Saloon 1989 BMW 325i Touring 1991 Mercedes 300TE-24 1991 Mercedes 190e 1970 Sunbeam Imp Sport
1966 Valiant 200 Custom 1964 Ford Fairlane 500 Station Wagon
Sept 15, 2014 9:10:29 GMT
davebmx - yes manual sunroof.
mrabody - fuel pump should be fine, can runs and drives. I drove it home on Friday night and it went quite well. Unfortunately it's been lowered to stupid levels so all 4 arch lips are battered from where the wheels have rubbed. I don't know if it could be carefully reshaped - it sort of has an outward flare? no rust. I wanted the offside for myself :-(
It's going to take me a while to get it stripped and there's a few bits I need which I'll be focusing on first. I'll work out costs and postage and get back to you with pics and prices as soon as I can.
How desperate are you?
Sept 15, 2014 19:12:47 GMT
No rush how much would you want for the handle posted
Sept 15, 2014 22:50:39 GMT
No rush how much would you want for the handle posted messaged
Sept 15, 2014 22:55:49 GMT
Hi, I need a fuel pump and possibly nearside wing if straight and rust free. Remember the four pot fuel pump is different from the six cylinder one.
Sept 16, 2014 8:55:31 GMT
I thought the difference related to tank capacity.
Sept 16, 2014 8:55:48 GMT
Sept 16, 2014 11:41:04 GMT
insert code here No. The return line to the tank is different. One has only one pipe at the top of the pump and the other has two, but I'm buggered if I can remember which is which right now. I think the six cylinder has only one.
You should be able to take the actual pump out of the frame and swap it though. The actual pump is interchangeable, but it's a lot of hassle when you can just get the right pump.
Sept 20, 2014 22:48:02 GMT
Can you post up a photo of the coilovers. May be interested.
Cheers
Sept 21, 2014 17:04:10 GMT
Here's the rears, fronts are still on the car. I don't have the tools for the top nut just yet. Already had some interest in them but depends what the weight is for delivery once I've got them off. I'll give you second dibs :-)
Sept 21, 2014 19:58:40 GMT
It's ok count me out. Having to buy other bits for it anyway and a holiday soon means I have £000 in my bank account.
Cheers anyway
Oct 17, 2014 15:19:01 GMT
Do you still have any parts for this by any chance? I would be interested in the diff if you've got it.
BMW e36 compact
Oct 18, 2014 18:52:48 GMT
Do you still have any parts for this by any chance? I would be interested in the diff if you've got it. Yes, still got pretty much everything. Haven't really got stuck into dismantling it that much yet. Diff is off though, I take it you can collect? How does £50 sound?
Oct 18, 2014 19:21:29 GMT
Pm'ed you
BMW e36 compact
Dez
Club RR Member Number: 34
Oct 18, 2014 19:38:37 GMT
got any of this-
passenger side front bumper black plastic insert if its mint (not likey i know!) front fogs if not cracked/chipped? sunroof handle if it didnt go. centre dash vents. cental locking relay if it works(in bottom of pass A pillar). rear load cover?
Oct 18, 2014 22:31:36 GMT
got any of this- passenger side front bumper black plastic insert if its mint (not likey i know!) front fogs if not cracked/chipped? sunroof handle if it didnt go. centre dash vents. cental locking relay if it works(in bottom of pass A pillar). rear load cover? Got all bar the front fogs, and sunroof handle. From memory bumper trim is good but I'll inspect it closely tomorrow morning, central locking works fine, so relay will be ok. Rear load cover is a bit scruffy but functional.
Rich
Club RR Member Number: 160
got any of this- passenger side front bumper black plastic insert if its mint (not likey i know!) front fogs if not cracked/chipped? sunroof handle if it didnt go. centre dash vents. cental locking relay if it works(in bottom of pass A pillar). rear load cover? Dez, this looks handy in so much as I need a 'box, I want your engine and you want bits from this breaker and I'm in bristol.. I need to sit down and send some PM's later tonight.
Dez
Oct 19, 2014 13:58:04 GMT
yep, all sounds good! eddy, can you let me know prices and condtion of that bumper trim, and a pic of the condition of the load cover?
might go for the rear coliies too, price dependent.
