jikovron
mechanical chaos
Sept 3, 2014 12:34:18 GMT
Abridged for sale summary ONLY bits and bats in this list is for sale,all the other gear is gone
38mm weber carb (33mm chokes/mains 190/air correctors 200/idle jets 55) £50 1397CC 8Valve Skoda Fabia engine £75 Escort van rear axle without springs and shocks £10 1920s kismet foot pump in working order £15 200x300mm aluminium radiator and fan £10 Rootes holbay cylinder head £30 (Edit, this is not a holbay head,just 1725cc normality in alloy) curse word old atco 75cc manual clutch £30 lawnmower engines MISC some sold 7HP electric start B&S engine £45 MUL-T-LOCK padlock and trans tunnel bracket for Gear lever £20
I will also happily swap for other parts etc
postage is possible on nearly all of it
Last Edit: Apr 4, 2015 10:15:45 GMT by jikovron
Sept 4, 2014 19:39:00 GMT
What jets is it on?
jikovron
mechanical chaos
Sept 5, 2014 22:13:45 GMT
ahh I had a look just before making the ad, but yet forgot to add the details ,
Mains: 190 Air correctors: 200 idle jets: 55 emulsion tubes : unknown as I didn't try getting them out
jikovron
mechanical chaos
Sept 6, 2014 16:18:37 GMT
Last Edit: Mar 9, 2015 19:59:30 GMT by jikovron
jikovron
mechanical chaos
Sept 15, 2014 19:28:57 GMT
Skoda fabia 1397cc OHV engine with apparently 52'000 miles under it £100 its basically a rapid, favorit and Felicia 136 engine but with minor design changes , hydraulic cam followers, a crankshaft ladder and a longer stroke which gives the same peak bhp as a 136 mpi but 16lb/ft more torque in the midrange evidently it would be a direct fit to a fabia, but can be fitted to a Felicia or favorit with a custom modified clutch thrust bearing and a Felicia timing cover, crank pulley+spacer and sump fitted, and can be adapted to fit the rwd cars with the same work and a rwd ring gear swapped onto the flywheel, crank spigot bearing fitment and a piece of angle iron fashioned to replace a bit of block webbing that was deleted I can deliver to a reasonable distance if anyone desired this excellent alloy piece rear axle £10 also a drop beam rear axle without springs and decent brakes the vin plate specifies a max load of 950kg, so with the axle assembly weighing 50kg it would allow a load of 900kg - the trailer chassis weight or indeed fitted to a escort van again
Last Edit: Mar 9, 2015 20:00:33 GMT by jikovron
Sept 28, 2014 10:38:04 GMT
bump
1993 Fiat Panda Selecta 2003 Vauxhall Combo 1.7DI van 2006 Mercedes Kompressor Evolution-S AMG SportCoupé
"You think you hate it now, wait til you drive it"
jikovron
mechanical chaos
Dec 13, 2014 21:45:11 GMT
I have this Kismet foot pump which looks have been made circa 1926 in sheffield judging from the patent age being of that that age i could describe the chassis as being crafted from wrought iron with a brass air cylinder of approx. 3" diameter it needs a shrader valve core fitted into the pressure test fitting (or the one its got screwed in as it leaks (if its blocked off if would be ok) all the internal leather work seems ok but its always worth a strip down to ensure its all greased up with fat,wax,castor oil or whichever interwar lubricant is recommended i have a slightly smaller kismet that i use to blow beads onto rims,,top up the daily beaters tyres etc and if you feel fit it is possible to blow a fully flat tyre up to 35psi in under a minute i would like £20 for it,and whichever postage is (5kg)
jikovron
mechanical chaos
Dec 26, 2014 10:37:37 GMT
Ford 2.0 pinto cylinder head, which looks to have done no mileage or had amazing oil as the camshaft looks like only the oxide black has been polished off, it has got abit of surface oxide here and there as its been sat around for ages it looks like the HG failed but the head surface looks great as iron typically does, the valve seats look similarly fresh SOLD TD04 Turbo of a 2.5 diesel , has sat around for literally years and is missing a v band clamp as I tried to clock the housings around but left it as is SOLD Circa 300x200mm radiator with a tiny fan on it, ideal for a bike (of which I don't know which this one comes from) or a charge cooler system radiator £15+postage weight=2.5kg Record upright band saw 1435mm blade circumference so available in many TPI ,currently has a 6tpi blade fitted which is a wood/plastic blade needs setting up tracking wise as it does throw the blade off when cutting thick wood however I suspect its best not used with thick planks etc. probably would cut steel as it has a suprising amount of torque but would need a different blade and some setting up of the guides probably however when it does snag the blade it does throw off the blade as noted other than that its in excellent condition SOLD Cheapy 6litre 1.5hp compressor, new and unused as its abit too noisey for my taste 2.2CFM @90psi 116PSI max SOLD Jaguar IRS chrome lower wishbone / driveshafts as a pair likely from an early v12 xjs £50 + postage jag irs rear handbrake calipers in working order, hydraulic sides unknown but likely an easy rebuild worst case £20
Last Edit: Mar 9, 2015 20:02:56 GMT by jikovron
Dec 26, 2014 12:53:47 GMT
How much for the turbo and compressor? Posted ch1
Dec 26, 2014 21:17:43 GMT
I'll have the turbo, whereabouts in C'field are you as may be able to get it picked up rather than have it posted, or I could pick it up myself in January
Dec 26, 2014 23:06:15 GMT
Any ideas how much postage would be for the bandsaw?
- '88 MK2 Golf 1.3 c - '07 BMW E91 335d - '94 T4 1.9d
jikovron
mechanical chaos
Dec 27, 2014 10:39:22 GMT
the postage cost on the bandsaw would be approx. £12 via the services of Parcel2go
The turbo and air compressor is sold provisionally to XBL but I shall keep any interested people in the loop as to any changes of plan or circumstance etc
many thanks
jikovron
mechanical chaos
Dec 27, 2014 11:46:08 GMT
the wastegate is built into the casting but externally exits into a screamer pipe or a pipe that rejoins a downpipe SOLD
Last Edit: Mar 9, 2015 20:01:44 GMT by jikovron
Dec 27, 2014 11:47:22 GMT
Will have the pinto turbo bits mate.
Dec 27, 2014 11:50:02 GMT
Also any idea if the pinto head is from an injection or if its got unleaded seats? Thanks
jikovron
mechanical chaos
Dec 27, 2014 12:26:30 GMT
The head I believe is a 79 carb 2.0 leaded head so I imagine one of the worst ones lol , however I think it hasn't had hardly any miles put on it as surface corrosion aside it is mechanically unworn
Dec 27, 2014 13:28:18 GMT
Ok, will leave the head, whereabouts are you for picking the manifold etc up please? Or could you give me an idea on posting costs. Thanks
has the manifold been sold?
Yes am having it, just need to sort out a date to collect.
jikovron
mechanical chaos
Jan 15, 2015 20:01:52 GMT
More added!
