Rob
You know, for kids!
May 14, 2007 20:49:09 GMT
Need a bit of guidance . . . I've been fiddling for days but the plugs are still getting sooted up and the exhaust stinks . . . I have twin SUs on the V8 and need some sure fine tuning tips. The pickup is my daily now . . . I have them balanced with the linkages off (you'd need to be pretty stupid to try and do it with them connected not that i'd know of course) The mixture screw - I assume clockwise is lean? Any idea how many turns out would be a good place to start ? Cheers guys and guyettes Rob
Rob
You know, for kids!
May 14, 2007 20:54:09 GMT
last year at CaRS - 'cruisin'
Last Edit: May 14, 2007 20:54:40 GMT by Rob
stinkwheel
Doctor Of Gonzo Journalism - One of gods own proptypes, never even considered for mass production.
May 14, 2007 20:57:00 GMT
I know nothing about balancing but do you have more pics in the readers rides eection or something as i need some more epics of your very very cool marnina
1973 Citroen Dyane 6 1980 Citroen Acadiane 1992 Citroen AX 1990 Citroen BX 1997 Citroen XM 1993 Citroen BX 1997 Citroen Xantia 1977 Citroen Ami 8 1996 Ford Escort 1989 Citroen BX 1997 Suzuki RF900 1988 Yamaha TDR250 1979 Honda CB400. 'I need less vehicles'
Rob
You know, for kids!
May 14, 2007 21:21:34 GMT
Aw shucks... some here - loads done since then tho
Last Edit: May 14, 2007 21:22:00 GMT by Rob
Dez
Club RR Member Number: 34
Tuning SU Carbs - Rover V8Dez
@dez
Club Retro Rides Member 34
May 14, 2007 21:28:05 GMT
theres a reson holley carb conversions are so popular
madmart
love is: valvebounce in top gear
you want to get a gunsons colourtune, its a see through plug that lets u see how the mixtures burning from either carb. made setting my tc's carbs a doddle mine was about 22 quid from halfrauds
Holleys are way thirsty and leak. Weber 38DGAS or DGAV is what you need on a RV8 3.5
I used to pay to have my twin SU RV8 ballanced and tuned by a mate in the trade who knows them well. Money well spent, he could make it run much sharper than I could.
May 15, 2007 10:36:29 GMT
definatly worth getting em looked at by someone who knows what they re doing, mine fires instantly cold or hot and will tick over reliably on or off choke and it don't hesitate or splutter as you open the throttle.
the standard carbs can and do run it fine so don't go spending money on new ones until you've had yours checked out properly.
Rob
You know, for kids!
May 15, 2007 11:39:22 GMT
Cheers - it does seem to be a black art.
I can get them balanced - mixture set (I have a colourtune) and idling but still there's hesitant acelleration (sp?) and bogging down.
Verdict: Get a man in !
May 15, 2007 11:43:17 GMT
i was gonna suggest an SU friendly rolling road but seems its already been mentioned
May 15, 2007 11:45:20 GMT
Is the dashpot fluid level correct in both carbs? Worth stripping them partially and giving them a good swill out with some WD40 and a rag, make sure they're all moving correctly and without stiction
Last Edit: May 15, 2007 11:45:55 GMT by Lewis
May 15, 2007 12:54:08 GMT
^^^ cause of many acceleration/flat spot probs with SUs
May 15, 2007 13:22:36 GMT
Rob
You know, for kids!
May 15, 2007 14:26:04 GMT
Rolling road would be a great idea.
Rolling road near Doncaster anyone ?
May 15, 2007 14:49:03 GMT
You can do a lot worse than Nottingham Carburettor and Injection Centre, Crocus St. The Meadows, Nottingham. Yellowpages webby will have the phone no. Or see if someone closer comes with a recommend. A chap I used to know took a TR6 down there and lef thtem just to "sort it all out". He was well preased with the results but I'd have done a slight freak at the bill though, they completely rebuilt everything. Mind you for the owrk they did the labour was reasonable. Anyway, I digress, they are who everybody of note round here uses for tuning and they can still set up twin SUs
