May 14, 2007 13:43:31 GMT
Hi, I am hopefully going to get round to refurbing the Cosmic alloys I bought before xmas in time for the summer shows, got some brand new centre caps Just got to polish and paint them. I could do with some tyre advice though, the Cosmics are 5.5J and 13 inchers. The wheels on the Viva at the moment are 13" weller steels either 5.5 or 6J I think and the tyre size on them is 185/70. So do I stick with 185/70 R13 tyres which look ok on the wellers but look quite tall or do I go with some lower profiles and have some of this stretch thingy? Where would the cheapest place to get some be as well, not many places seem to stock 13 inch tyres nowadays Ps Original factory tyre size was 155/80R13
bstardchild
Club RR Member Number: 71
May 14, 2007 13:54:51 GMT
Hi, I am hopefully going to get round to refurbing the Cosmic alloys I bought before xmas in time for the summer shows, got some brand new centre caps Just got to polish and paint them. I could do with some tyre advice though, the Cosmics are 5.5J and 13 inchers. The wheels on the Viva at the moment are 13" weller steels either 5.5 or 6J I think and the tyre size on them is 185/70. So do I stick with 185/70 R13 tyres which look ok on the wellers but look quite tall or do I go with some lower profiles and have some of this stretch thingy? Where would the cheapest place to get some be as well, not many places seem to stock 13 inch tyres nowadays Ps Original factory tyre size was 155/80R13 Don't think you are going to get some of this stretch thing on 5.5J rims and keep the speedo anything like close to accurate Not sure that you current tyres are that close now!!
May 14, 2007 14:02:10 GMT
I see, the difference between factory tyre size and current tyre size is -11% so at 70mph indicated I would actually be doing 68.69 which is ok as I don't mind it under reading.
Last Edit: May 14, 2007 14:02:29 GMT by Deleted
Seth
May 14, 2007 14:41:01 GMT
Here's some 175/70's on some 5.5" Cosmics for you 175/70 is pretty much identical rolling radius as 155/80. While not Cosmics, these are also 5.5". The rears are 175/70 and fronts 165/70. Those sizes should be available easily from anywhere We just paid £120 ish for the new decent quality set in the last photo. I wouldn't be too concened about teh accuracy of your speedo. It'll alter a little if you have a different size tyre but then who said it was right in the first place? Just make a note of what speed everyone else goes past the speed cameres with out getting flashed
May 14, 2007 15:17:01 GMT
Cheers Seth, those 175/70's look fine so I will get a set of those I think I said they were hard to find as I was checking a website that didn't seem to have any 13" tyres on, but yeah they should be readily obtainable
bstardchild
May 14, 2007 15:30:12 GMT
I see, the difference between factory tyre size and current tyre size is -11% so at 70mph indicated I would actually be doing 68.69 which is ok as I don't mind it under reading. 11% under at 70 mph is 62mph I agree under is better (safer) But don't forget your odeometer will read 100 miles covered for every 89 miles so correct for that if you work your mpg out and find it's better than expected
slater
Club RR Member Number: 78
May 14, 2007 15:37:53 GMT
Surely its better to read faster then your attualy going? Oh yeh you want 165/60s too
May 14, 2007 17:04:51 GMT
I see, the difference between factory tyre size and current tyre size is -11% so at 70mph indicated I would actually be doing 68.69 which is ok as I don't mind it under reading. 11% under at 70 mph is 62mph I agree under is better (safer) But don't forget your odeometer will read 100 miles covered for every 89 miles so correct for that if you work your mpg out and find it's better than expected Yeah I put 11% instead of 11mm difference It's actually -1.87% Surely its better to read faster then your attualy going? Oh yeh you want 165/60s too Under reading means that the speedo will be reading faster than I am actually going, Ie the speedo reads 70 but I am doing 65 is better than the speedo reading 70 but the car actually doing 75 as I don't want to get a ticket I think we are both making the same point though I always get confused here actually, is that under reading or over reading Lol 165/60s would be 8.65% smaller than stock tyres so would undergear it quite a bit, would help acceleration though I guess
Last Edit: May 14, 2007 17:08:41 GMT by Deleted
Odin
May 14, 2007 18:40:53 GMT
145/60s and slam FTW! Only 15% out, it's all good.
IMO 185/60s were made for these rims 175/70s should do the trick.
Mr K
May 15, 2007 12:33:00 GMT
11% under at 70 mph is 62mph I agree under is better (safer) But don't forget your odeometer will read 100 miles covered for every 89 miles so correct for that if you work your mpg out and find it's better than expected Yeah I put 11% instead of 11mm difference It's actually -1.87% Surely its better to read faster then your attualy going? Oh yeh you want 165/60s too Under reading means that the speedo will be reading faster than I am actually going, Ie the speedo reads 70 but I am doing 65 is better than the speedo reading 70 but the car actually doing 75 as I don't want to get a ticket I think we are both making the same point though I always get confused here actually, is that under reading or over reading Lol Under reading = car doing 70, the speedo is under reading....... and saying 68, so you do a 'indicated' 70mph, and your now speeding.... over reading is the way to go! (i.e. speedo says your going faster than you realy are)
