I'm considering lowering the firenza and was wondering the best route to take. Chopped springs is somthing I'm not keen on and if it's too low is have to buy new ones. So question is are there coil overs available for vauxhall firenzas or vivas ? That way I could lower and raise it to how I want it. Or suggestions on what springs will fit it without cutting.
rodit
Aug 22, 2014 18:36:53 GMT
Just have a chat with wacky mick wilkes with the ha van at gathering. Very approachable guy and knows those cars better than most.
Low and slow
Why can't i tune it?
rodit
Aug 22, 2014 18:37:07 GMT
Low and slow
Colonelk
Club RR Member Number: 83
Coil overs on classicsColonelk
@colonelk
Club Retro Rides Member 83
Aug 22, 2014 19:21:00 GMT
Gaz sell coils for these I'm pretty sure :-)
Aug 22, 2014 20:31:43 GMT
if gaz don't you can buy coilover conversion kits to make your standard struts into coilovers. Most rally parts stockists will sell a kit
Maximum signature image height = 80pixels
v8ian
I had all the bits ready to do an adjustable lowering set up for my HB, Fronts were going to be BL mini Adjustable Koni coilovers (2" springs) , a bit of strengthening around the top of the shock mount would be advisable as you are now putting the suspension loading thru the shock mount, on the rear I was using Corsa pigtail -30 springs with adjustable platforms, which makes the rear of the car adjustable, on the rear you need to be aware that lower the car too much you will have problems with the rear control arms fouling the chassis.
Thanks for the input guys I'm in two minds what to do now but ill look under the car later on and see how the suspension is. made up coil overs or lowering springs and cups. cheers again
v8jim
Aug 23, 2014 22:35:46 GMT
Superbean.... Viva/Firenza/Magnums are double a-arm fronts and live axle rears, no struts This thread has a lack of pics.... There is someone I believe Coggers uses that does lowering springs that have been very popular also ^^^^^^^^^^ that's mine it's on GAZ coilover and 325lbs springs which aren't strong enough so I have some 450lbs ones waiting to go on it, it's also got corsa rear springs with adjustable platforms
Max sig pic size: 80px
That looks like how I want mine just taking my suspension apart now to see how the shockers springs look. Then I'm going to see it I can get anything sorted on it.
v8jim
Aug 24, 2014 14:29:34 GMT
Just fitted my 450lbs springs they're 7" long 1.9" id on GAZ coilovers with an open length of 11" between centre of the eyes It's running an XE which is considerably lighter than a slant so you might need 500lbs springs but results in a stance like this with room to go up or down a bit and it drives really nice,not to stiff just nice
Aug 24, 2014 21:47:14 GMT
That looks fantastic mate , I'm going to take your advice on board and see shat I can find
