Bought this little coupe only a few months back with intent to replace an old car but in the time I've had it circumstances have changed and now it's up for sale to a new owner
When I bought it it was on the bottle tops and since owning I have moved those aside for a set of staggered ats classics 8j rears and 7 fronts
I have also put a 4-2-1 stainless manifold with lambda on it and had the back box already mounted
Is sitting on 80 fronts and 60 rear spring with fk shocks
Have fitted a gt cam as old cam wis a little worn on the lobes
Uk legal pressed plates
Has g40 front and rear seats
Changed the grill to something a little different with polo emblem on it
Pinstriped the bumpers for the gt effect
Also removed the bump strips along the sides
Clear indicators
Wax oiled the under side
Dewipered rear
Also has the leiderschleit ant roll bar blocks also
Is a really cool car but I just won't be using it anymore so will be better taken on by someone else who will use it
With it being the cl has the 5 speed gear box which is good however linkage is lose but
Engine is running lovely on 105k
Only real rust on the car is bottoms of the doors but is still a really good condition car for the age
Mot till October-only advisor was number plates last time which have now been changed
Tax I believe is a month or 2
Priced at £1100
Located in Cwmbran South Wales
07771259659 text if possible as I work long hours but will reply ASAP
Clear indicators
Dewipered rear
Priced at £1100
