I have a austin mini special edition, one litre high compression engine, mot till febuary next year, taxed till end october this year, metallic silver, valour seats with zip up storage pockets, tinted glass, valour door cards, three clock dash with rev counter, heated rear window, twelve inch wheels, servo assit disc brakes, spot lights, chrome grille and bumpers, runs and drives great no real issues, no rust, loads spent see below, ready to jump in and use, sale only as the car is not being used and has been replaced with another classic, very solid mini, no rust in the subframes, very pritty car to look at
the car was a first home restoration for previous keeper
in the last year the car has had four new nankang tyres, fuel filter, wiper arms and blades, rear lower valence panel, off side front quarter floor pan, points and condensor, new brake calipers, new pads etc, new battery, hazard lights fixed, lamp aim adjusted, replacement subframe mounts and track rod end, adjusted wheel bearings, clean and adjusted rear brakes, rebuild carburettor, replaced plugs etc, adjust dwell angle on timing, various rust cut out of floor pans and professional welding repairs carried out, rectified fault with tell tail light on fog light switch
seven years ago the car had new wings, scuttle repair panels, windscreen closing panel, inner wing rear edge panels, a panels, sills, rear valance closing panels, 2 second hand doors, new special edition decals, rear bumper, replacement lock set, replacement mohair carpets, sill trims, gutter trims, new mirrors, new windscreen rubber, new drive shaft end, new discs and pads, new rear shoes and cylinders, exhaust mountings, new grille, radio ariel.
at this time the engine was removed and stripped, new piston rings, new main bearings, new big ends, new thrust bearing, new oil pump, new clutch assy, new timing chain, valve guides and seats, oil pressure switch
bad point - interior now needs tiding up again rear door cards missing very easy to get though, paint work is still very good whilst nice and shinny and no rust coming through despite now being seven years old, the original finish was poor it was never flattened before laquer
£1595 ovno
cant seem to upload pictures so there at - www.gumtree.com/p/cars-vans-motorbikes/1984-austin-rover-mini-25-special-edition/1076452873#photo-content
£1595 ovno
