mt2man
Jul 12, 2014 19:26:36 GMT
Just thought I would share some pics of my Vauxhall midi (Isuzu fargo), I won it on ebay for £400 as "spares or repairs" due to a leaking clutch master cylinder, but it came with a refurb kit so an hours work and it was fully driveable Its a long wheel base model, with windows all around, its been painted a sort of satin black so looks very rough and ready, but I love it! haha It was originally an 8 seater so I removed the rear seats to make room! So the plan is to use it for a few months for tip runs and building supplies and then carry on with a camper conversion! The rear is 10 foot long by 5foot wide so plenty of room! First purchase for it was a set of 4 Pajero alloy wheels, £20 ebay bargain they should look awesome and fill the arches quite well Quick 10 min clean, they will easily end up polished to a mirror finish so will be great! This is my plan for the camper conversion, it will be a corner sofa bed, the removable section is the width of the bed so will be removable as and attach at the top of the sofa as a back rest. The drawing isn't to scale but with a 6ft 3 bed it will leaves me with 4foot of worktop space at the end of it! And leaves me the other side for push bikes inside the van The 2 windows behind the drivers side will be boarded up, ill probably paint the inside of the windows and then put up a carpeted wall the whole length of the van, with some insulation behind to help keep warm! I am planning on lowering it, its leafs at the rear and big beefy springs up front, will make up some 2.5" lowering blocks out of steel box section with longer u bolts for the rear and possibly just cut a coil on the front, but don't think it will quite give me the drop I'm after so will have to look at other possibilities?
Last Edit: Jul 12, 2014 19:28:21 GMT by mt2man
Jul 12, 2014 20:10:08 GMT
great plan and very different
mt2man
Jul 12, 2014 20:15:03 GMT
It's going to be different for sure! And a lot cheaper than VW's and more room! Haha
olig
Jul 12, 2014 21:44:04 GMT
I'll be watching this, got a spare van I'm breaking if you need anything. My Thread is here I've got 1 owner 1989 60000 minibus and and a very rusty camper. Theres another on here too somewhere
Last Edit: Jul 12, 2014 21:49:38 GMT by olig
mt2man
Jul 12, 2014 21:51:24 GMT
The link isn't working! But I might actually be after a side sliding door?! I've had a search on here for project logs but only really found 1 or 2
It's solid everywhere but door bottoms, the front 2 aren't too bad really but the side door could do with replacing.
It's got the old column shifter which takes some getting used to! Haha
olig
Jul 12, 2014 22:13:05 GMT
Fixed the link, the side door on my breaker is rusty and warped so will be no good. Its got good running gear, its just very rusty, although the chassis is still solid. The gutters and the front floors are the worse bit I take it yours is a diesel? mines petrol and does about 20mpg ? My old camper has the column shift, which I prefer fo extra coolnees, don't go too small on the tyres on the alloys as the gearing on these vans is really high, 1st is useless already.
mt2man
Jul 12, 2014 22:37:59 GMT
I've seen your build and I love it! Yeah mines diesel, not sure what this is getting to the gallon yet but I'm not bothered really! Haha I'm on the hunt for tyres for my wheels now and will get them fitted soon
mt2man
Jul 13, 2014 21:44:12 GMT
Has anyone know what fuel pumps these use? Looking at running it on veg oil the engines are bomb proof so just making sure the fuel pump is upto the job! Veg oil is around £1 a litre so should save some money!
Jul 13, 2014 22:28:00 GMT
Nice, i will be getting a ambulance version this week and the plan is to convert to camper but leave as ambulance outside. Will follow progress with interest.
Jul 13, 2014 22:49:25 GMT
Looking forward to seeing this on those Pajero wheels, especially after seeing the Rascal Mystery Machine put on Turbo Vecs.
mt2man
Jul 14, 2014 10:15:52 GMT
I suppose they do look kind of similar to the vecs haha, just 600% cheaper!
It deffo needs hitting with the stick to match though!
Jul 14, 2014 11:03:39 GMT
I think the design will work better than the TVs on the Midi and in my head they're a top wheel choice for this van even as it looks now. You should get some orange paint/tape to go in that recess down the sides of the van so it links up the front and rear indicators.
mt2man
Jul 14, 2014 11:06:12 GMT
That's a fantastic idea I love the orange strip idea might be stealing that! Haha
Jul 14, 2014 18:41:14 GMT
Love these. Well done for saving one.
olig
Jul 14, 2014 21:23:29 GMT
Which diesel engine has it got 2.0, 2.2 or 2.4td?
mt2man
Yeah it will be saved, I doubt I'll ever sell it now as it essentially will owe me nothing after it's saved me hundreds on tip runs etc! This is the 2.4 non turbo, it's not slow though! It's got the column shift which doesn't return to the middle with the springs so takes a little getting used to changing gear but it's a sweet engine and box it's only done 70k! Barely run in for one if these lumps haha
Jul 15, 2014 15:08:26 GMT
Looking forward to seeing this progress. I've nearly finished the camper conversion on my mitsubishi l300. Wish that was column change but they changed em to floor change later. If I ever find one that's been broken I'll swap mine to column change.
trimtechniques
Porsche 928 4.7 ltrs of German grunt. Mazda MX-5 MK1 Dakar. VW T4 camper
Jul 15, 2014 15:35:17 GMT
This is going to look good. Bookmarked!
mt2man
Jul 18, 2014 15:22:24 GMT
Does anyone know a simple way of getting the side sliding door to open wider at all? I mean further away from the body?
I will be trial fitting the wheels and will be rolling the arches but I'm a little worried they will be flared too much that the door won't be able to open the whole way haha, worse comes to worse I'll just have to limit the travel in the door slider so it doesn't go that far back!
olig
Jul 18, 2014 22:10:37 GMT
If its only for fine adjustment put a couple of washers between the door and the bracket on the 2 top and bottom front bolts. Theres some adjustment in the sliding bit as well, but any tweeks would stop the door sitting flush when closed. Seen a few with Frontera wheels without any mods.
On my other van the rust and previous repairs had caused the door to warp catching the door card when it opened and sticking out in the top corner when closed.
