Jul 12, 2014 17:25:18 GMT
,I'm after some rear calipers for my bmw, they need to have the cable handbrake, and they need to work well.
They are 272mm solids.
Sierra maybe, but to they work ok with a cable handbrake?
Jul 12, 2014 21:02:25 GMT
Why not use BMW calipers ? Mini items are cheap.
Paul H
Jul 12, 2014 21:24:14 GMT
oh right they have cables!
Copey
Jul 12, 2014 22:14:04 GMT
i thought, MOT speaking, all handbrakes are cable?
yes but say ont he bmw, it has rears taht are non cable and little drums insie of the disks for the handbrake
BMW Mini has cable handbrake that operates on the disc - Paul H
BMW Mini has cable handbrake that operates on the disc - Paul H Hardest pArt will be finding a set up the right size Alfa romeo 156 and 159 have cable handbrake Most peugeots 106, 206,306 etc have them
Jul 13, 2014 10:21:49 GMT
thats interesting then i wonder if the mounts are the same!
i know sierra ones fit as a friend of mine has them on his car, but he had to weld new mounts on. I don't know if itll handbrake well with the cable set up.
This is because the car has ABS, its a rally car, and if i brake, and pull the handbrake even a tiny bit it locks the rears on, and then you have to play with the handbrake to get it off./.
Jul 13, 2014 11:23:19 GMT
This is because the car has ABS, its a rally car, and if i brake, and pull the handbrake even a tiny bit it locks the rears on, and then you have to play with the handbrake to get it off./. If it's a rally car why not fit a hydraulic handbrake?
Last Edit: Jul 13, 2014 11:23:37 GMT by carat 3.6
handbrake rear calipersChasR
@chasr
Club Retro Rides Member 170
Jul 13, 2014 11:37:28 GMT
Some rally cars still need to hold an MOT.
Jul 13, 2014 12:30:10 GMT
as i say it gets the abs confused and it locks the rear brakes on hydrolically.
Jul 14, 2014 20:51:42 GMT
Some rally cars still need to hold an MOT. As long as the cable handbrake is still fitted and working, it will pass an mot with a hydraulic handbrake.
Jul 14, 2014 20:57:26 GMT
as i say it gets the abs confused and it locks the rear brakes on hydrolically. Can you not fit a switch to disable the abs when your rallying? It doesn't matter if the handbrake is cable or hydraulic, the abs system is only reading the speed of that wheel.
Jul 14, 2014 21:02:42 GMT
no i fitted the abs to go rallying its the best thing you will ever do to a rally car on tarmac, its not normal abs, its special abs.
but with out abs, when you brake you cant pull the handbrake, he system is hydrolically locked, so you coe to a corner, brake, light pressure on teh bar, and as soon as you lift off bar comes up and the car goes around.
Now its very hard to guage, foot off brake and pulling the bar. If you pull the bar when braking, it thinks something is goign wrong with the rear brakes, pressurises the handbrake cylinder and the rear brakes lock on.
with the vcable it cant do that, or maybe ill have to fit very small extra calipers and a seperate HD bar system
