doobie
Jul 11, 2014 17:18:53 GMT
So despite several hours of googling i cannot seem to find the external measurements of the mini / 1100 engine and gearbox in transverse form ie length x width x height. Can anyone either point me to a web page or pop out to their own motor with a tape measure.... Many thanks in advance.
Jul 11, 2014 19:05:25 GMT
I would, but my transverse car is 70km away... However, you probably should specify if with or without ancciliaries. 'Cause that makes a big difference
doobie
Jul 11, 2014 19:11:00 GMT
Ah good point... with ancillaries i guess... although width is my least worrysome dimension ...
Jul 11, 2014 21:48:13 GMT
With height I can be of aid - I have a block, geabox & head with valve cover here :-) The rest is stashed somewhere I can't reach.
Height is about 61cm / 24".
doobie
Jul 11, 2014 21:50:08 GMT
ah cool thank you very much..... thats a great help...
Jul 13, 2014 22:25:22 GMT
If there's no reply already i can measure up mine tomorrow evening. Not sure if its anyhelp but ive had engines in the boot of a mk4 golf and there was loads of room to spare in all directions
doobie
If you could Rob i would appreciate it....
stevea
Including radiator, 29 1/2" wide. Sump to top of radiator, 25 1/2". Sump to rocker cover, 24" Width across clutch cover, 13 1/2". Across engine, distributor to carb, 20 1/2"
doobie
Jul 14, 2014 16:52:18 GMT
Thank you muchly Steve just what i needed have a picture of a cool GT6 for your trouble......
Jul 17, 2014 19:16:50 GMT
Click picture for more
