andyborris
As a follow on to my question about Rose Joints. I know a welded repair on steering linkages is a MOT fail, but what about fabricated turnbuckles which are screwed onto a steering rack. These are made by welding a tube onto threaded bosses and are not a repair of existing components, but a new part. Still a fail?
rodney
https://www.facebook.com/RD-vehicle-transport-and-recovery-services-525622614268010/
ill ask my mot guy see what they say , they is a bmw guy on fb that does modded front hubs that have been welded and some have gone on street cars,.
facebook: rodney dean / rd transport
If it looks like frankensteins ugly uncle then it will fail ,but if it looks neat and well done then see no reason why it won't pass as long as safe and up to the job in hand
If it's welded properly they'll never tell anyway...
Dez
Club RR Member Number: 34
Welded Steering Components ?Dez
@dez
Club Retro Rides Member 34
buy some taps and dies and do it properly. i hate those weld on threaded bungs, there really isnt any reason to use them other than not having the right equipment to do the job.
adamb
Don't see any issues, what about all the adjustable tca's compression struts etc available for escorts for example
They're all welded
Dez
@dez
yep, because its a cheap and cheerful way of sticking them together. it may never break, but it looks curse word and isnt the correct way to do it.
in engineering terms, the correct way to do it is to start with the correct size tubing, bore the ends then tap them to size. its not even like its any harder if you buy the right size tube to make them.
Jul 14, 2014 15:11:23 GMT
There's a very good reason to use them - most of the time you don't need that kind of wall thickness down the rest of the tube.
andyborris
Jul 14, 2014 18:30:32 GMT
In the end it was cheaper (and easier!) to get a threaded tube made.
Probably overkill, but it's made from 3mm wall tube, on an 12.5mm hole!
Thanks for all the advice, car is now back on the road, should really update the Readers Ride thread.......
