eurogranada
For my Granada coupe I'd like to add a Window Louvre to the rear window as was the rage in the 70ies. I've not had much luck finding any online.
Any of you know of a supplier?
Also I'd like to order a front windscreen moulding that weighs in at just over 2 kilo's according to the seller. Shipping to the Netherlands however is quoted at 50 pounds. Almost what the part itself costs. Are there cheaper ways? Anyone here care to help me out with a more reasonable solution?
fred
WTF has happened to all the Vennies?
If the front windscreen moulding is coming from the UK the overseas postage I went to the royal mail site I put in a 3kg to be sure and '' globalvalue Delivery Aim 3-5 days Up to £100 Not Tracked £27.80 + VAT '' Wheres the seller based?
And rear Louvres ? Ive been after one for the Manta for a while, seem take your luck at autojumbles I guess. I will keep my eye out for MK I granda ones on my forays mind
'79 Cossie ran Cortina - Sold
2000 Fozzer 2.0 turbo snow beast
'85 Opel Manta GSI - Sold
03 A class Mercedes
Looking for a FD Ventora - Anyone?
eurogranada
UtterPiffle might be able to help you. He crosses the Netherlands regularly on his route from the UK to Germany (and vice versa). His usual route seems to be Thanks, that may be sensible as I live in Eindhoven... I may just contact him. Shipping withtin the UK is only12 pounds or so so that would make quite a difference!
eurogranada
If the front windscreen moulding is coming from the UK the overseas postage I went to the royal mail site I put in a 3kg to be sure and '' globalvalue Delivery Aim 3-5 days Up to £100 Not Tracked £27.80 + VAT '' Wheres the seller based? And rear Louvres ? Ive been after one for the Manta for a while, seem take your luck at autojumbles I guess. I will keep my eye out for MK I granda ones on my forays mind Yes, it would be coming from the UK. Hm, so that is about half of the quoted cost. I'll see if the seller can do something based on these numbers and otherwise I'll try the suggestion of the first poster. Thanks for being on the lookout as well. They seem to be tough to find.
omega
we going to Holland end of august so might be able to help
bortaf
Postage has changed recently, if the item is too long to be a small parcle the price jumps up a huge amount (relativly) cos there is no med or large oparcle option for posting abroad, that could be the reason for the high postage? Global express is quoted at £50 on the PO web site, the seller might not have scrolled down to find the cheaper option?
R.I.P photobucket
eurogranada
Thanks all,
for now it seems the part is the wrong version. I need a windscreen moulding for the wide metal trim version of the granada and the part I finally found tunred out to be for the narrow plastic trim version.
As for the window louvre, If anyone knows of a supplier I'd like to hear from you.
