cjhillman
May 27, 2014 17:25:27 GMT
For some reason I'm struggling with wiring in my air horns! I followed this diagram but its not working : This is the over all wiring. The negative from the compressor and the relay 85 are bolted to inner wing. The relay positive 87 is going to the battery terminal and was clamped behind. The switch goes to the 86 pin and the black wire is screwed the inner cill. I will tidy this up later once it works and there is a fuse to go on the battery terminal . Thanks, Chris
v8ian
May 27, 2014 18:15:27 GMT
are you getting power to leg 86 when you press the button? ?
cjhillman
May 27, 2014 19:16:35 GMT
I haven't got a meter to hand at the moment. I tried connecting the positive straight to the battery and it didn't do anything then :s I did get the compressor to turn the other day buy connecting a 9v bat to both terminals though.
v8ian
May 27, 2014 19:54:06 GMT
connect the live from the switch to the feed to the compressor, push the button, if it works, its a duff relay, if it dosent, you have either no power going thru the switch, you have picked a no live feed, or the switch is fubarred.
Rich
Club RR Member Number: 160
Air horn isn't working! Rich
@foxmcintyre
Club Retro Rides Member 160
It sounds like you are just connecting earth to earth with the switch if you say 85 and 86 are earthed. You need a positive feed there, connect 85 to the battery positive if the black wire from the switch is earthed!!
Rich
@foxmcintyre
Also, fuses! Where are your fuses?! Tut tut..
