Howdy groovers,
The build continues slowly.....so in the meantime I thought I'd procrastinate with the engine (instead of sanding, sanding, sanding...). What cylinder pressures should I be looking at for a healthy kent? 130-150psi with 15% tolerance between cylinders?
