dpb
May 14, 2014 17:58:39 GMT
hey i wanna start preping/ sanding my car. should i get a cheap electric sander?, Should i go to bare metal ? not fused if the paint job is not that amazing as i might get it done properly done line at some point so give me all your TIPS N TRICKS please lol ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) cheers ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
May 14, 2014 18:28:21 GMT
advice.. Only start prepping the WHOLE thing if your ready to Spray soon.. No Need to go back to metal unless you have a specific reason to.. 2k Solid colors are easy enough to spray.. and easy to work with after painting. Wear a Mask The effort you put into the preparation pays off in the end Be careful what you read online.. ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
Paintwork, Fabrication, Performance Work, Engine Transplants, Part Fitting, Banded Steelies, Stretched Tyre Fitting, Wheel Refurbs - Compete Resprays from £450..
Search ''Firefly Speedshop'' on facebook! or Garage communities on Retro Rides!
dpb
May 14, 2014 21:09:50 GMT
thanks for the advice ![:D](//storage.proboards.com/forum/images/smiley/grin.png) so how much do i sand off then ? just so its not shiny ? (newbie questions) lol
rodney
https://www.facebook.com/RD-vehicle-transport-and-recovery-services-525622614268010/
May 14, 2014 22:21:53 GMT
its prob easier to look up painting a car at home on youtube , itll explain it better to you ,.
facebook: rodney dean / rd transport ![](http://i564.photobucket.com/albums/ss82/rodney_racing/40322327267617s.jpg)
rodney
May 14, 2014 23:55:12 GMT
if your repairing dents then remember that each dent is 2 dents , the obvious bit being inwaeds dent , the not so obvious being the edges of the dent sticking out , push/tap dent out while going back to tap the perimeter back in , a long rubbing block is your best friend on these , you nearly always get pin holes in the filler so use some stopper to sort that ,
if you flatting it down for a solid gloss colour then it can hide a lil bit more tan a base and clear , get a rubber pad and wrap your paper around it , avoids finger marks etc , 800 wet for rubbing for a repaint is fine if doing all by hand , in most cases you only need to prime repairs and where the paint is bad or been broken through, you want it to be smooth with little to no orange peel in the prepared area , make sure all the shine is gone , if the paint is good and smooth you can get away with scotching the car down to loose the shine , make sure you get all edges good or itll flake later on,.
May 15, 2014 20:00:30 GMT
if you don't care what it looks like you can use a red scotch pad to key any sound paint , anything flaking or scratched will need sanding
