May 12, 2014 10:42:16 GMT
Stu_B
Investing in rust!
May 12, 2014 11:04:13 GMT
May 12, 2014 11:15:37 GMT
I've got 5 Suzuki Grand Vitara 16" wheels for my Mahindra that are also rusty on the rear. Local firm quoted £100 to blast them and powder coat in whatever colour I wanted. Having a pert little bottom (tight 4rse / part Jewish) I looked at alternatives and have bought a large tub from DIY store that is big enough to take a wheel for under £10. Plan now is to roughly clean up with wire brush in angle grinder, paintstrip and then clean remains of rust via electrolysis.
Paul H
taurus
May 12, 2014 11:25:45 GMT
As Stu_B for me. I've just done my Viva ones using a twisted knotbrush in an angle grinder idea. It worked fine (apart from my old angle grinder seizing up its gearing half way through which made me jump about a bit.)
Gave them a couple of coats of Dinitrol Converust and painted them up. Came out fine.
May 12, 2014 11:29:09 GMT
Hi, as Paul says but just getting them blasted and then you painting them might be cheaper. Electrolysis is the way to go far cheaper and most effective. Rotary wire brushes tend to polish the rust and not remove it.
Colin
May 12, 2014 12:18:18 GMT
I'm looking at super low cost options as I already have the paint knocking about lol.
I thought about the knot wheel, but have seen/heard bad things about them when they break. I'm not a massive fan of the angle grinder at the best of times as it's one of the only tools that scares me (I can be a bit accident prone) lol.
Blasting and powder coating would be great, but I could probably get another set of alloys that don't need any work for less.
Last Edit: May 12, 2014 12:19:47 GMT by joem83
taurus
May 12, 2014 16:09:24 GMT
So long as you use a decent quality knotwheel they're fine. They throw the occasional strand, but the trick is to wear proper overalls and a face mask.
93fxdl
Enter your message here...
May 12, 2014 16:29:01 GMT
Twist knot in angry grinder, gloves and eye protection, then let youngest son loose, Four 16 inch wheels from a trooper cleaned and painted, Plus learning experience and father/son time Ttfn Glenn
grumpy
May 12, 2014 16:36:42 GMT
Last Edit: May 12, 2014 16:37:03 GMT by grumpy
taurus
May 12, 2014 17:39:16 GMT
Seconded. I use that type from Machine Mart (my angle grinder spins a bit faster than the max rated speed for them but doesn't seem to cause any issues ---- so far!)
May 12, 2014 19:32:11 GMT
93fxdl
May 12, 2014 20:38:31 GMT
Also when cleaning, wear a dust mask, for a quick job, hand wire brush followed by one of the, paints over rust finishes, or keep the patina types happy, and run as they are Ttfn Glenn
I've personally used a wire brush attached to a drill and that works well
They don't look bad at all, I think I'd go for the electrolysis treatment first to shift the first layer of crud, then give them a going with the wire wheel.
As mentioned, wire wheels can just polish the rust so you do need to loosen it off before trying to shift it.
