Apr 27, 2007 20:31:05 GMT
I'm polishing/detailing a set of Gemini 8 spoke alloys to fit on my type 3 (full details here www.vwscotclub.co.uk/forum/forum_posts.asp?TID=3423 ) but I have 2 problems. 1, the wheels were cheap (very cheap) but didnt come with centre caps, anybody have any idea where I would get caps or something that would fill the hole? 2, Any idea where I would get locking wheel bolts? Any ideas gratefully recieved, Dave.
Apr 27, 2007 22:16:35 GMT
caps wise, try ebay, autojumbles for 2nd hand ones.not sure about new ones. for the bolts, places like www.customspeedparts.com/index.html~ and www.machine7.com/ should have them, failing that a local motor factor may have them. my local one had allsorts of type 4 stuff on the shelf, which was a surprise. HTH.
Apr 27, 2007 22:34:57 GMT
what pcd is that? i think i need to buy a car to suit!
Apr 27, 2007 23:18:26 GMT
what diameter hole is it ?
sav
Apr 27, 2007 23:18:57 GMT
Going back in time to 1987......... I made some centre caps for a set of Appliance wire-mags. Pretty sure I used aerosol can lids that just fitted inside the centre, gave them a coat of silver and they looked fine. I recall I got given two original Appliance caps sometime after, but were very rusty with very little chrome left.
Wheels were on my 1303 beetle, so probably same centre dimensions.
I bought some locking wheel nuts from ebay. Having seen them in Halfrauds for £50 odd per set I was well pleased when I managed to get about 4 sets for £25.
Well pleased that is, until I tried to tighten them up onto my car. All the threads disappeared and I was reminded of the old adage that - you gets what you pays for!
To be fair I contacted the seller and he said that he would refund me but I never got around to returning them. They were supposed to be Wolfrace bolts too!
ger
Last Edit: Apr 28, 2007 8:04:11 GMT by ger
markbognor
Club RR Member Number: 56
Centre cap ideas?markbognor
@markbognor
Club Retro Rides Member 56
Is there a shoulder for them to sit on, i can't see too well from the pic, if so I could probably get round to making you a set from acrylic. (If I can find some mirror backed) I've had a set on my brms on the merc for almost two years. I hold them on with outdoor sticky fixers and have never lost one, this is why there needs to be a shoulder, rather than them being an interference fit with the diameter of the center bore. Here's a couple of pics of mine. I'm in school this morning supervising some Y11's catching up with coursework so i'll have a play and post some pics.
diff
aerosol lids definately with some stick on logo centres of ebay
markbognor
@markbognor
Try 1, Mirror backed acrylic, then backed with a black disk. Not very good. The mirrow VW looks ok but the etch is not clear enough to show the black. Try 2 + 3 Etched straight on to the black, the etches are reversed so there is a positive and negative. Look ok but not great. Would also have the texture of the etch on show. Could be covered with a clear disk, but attatching would be a problem. Try 4 Etched the logo onto clear acrylic, then turned over and backed with black. This looks the best so far, but again there is tthe problem joining the two layers because any glue used will show through the clear. I don't think i'm going to be able to come up with anything suitable.
Apr 28, 2007 10:55:39 GMT
tonycocacola; Machine 7 was my first port of call but without success. They did help me out with mag washers but as the previous owner of the wheels had been using alluminium washers!!!
surprisingskoda; they are 4x130 Beetle pattern.
guz; It was a bit too obvious for mr to measure that before posting, I will check later.
ger; Cheers for the link, I will chase up details later.
markbognor; those are cool but the wheels I have don't have a tall enough shoulder and the bearing caps/rear hubs would stick through. From what I can see the caps on these wheels would be fitted from behind and there is a shamferred edge to hold the cap in place.
sav; Cool Idea, I will go and measure up some lids later.
hongkongphooey; not convinced I'm affraid but I do like the method of fitting.
Apr 28, 2007 18:52:52 GMT
hongkongphooey; not convinced I'm affraid but I do like the method of fitting. The do 3 pointed ones too.....i think they're well cool but perhaps not for your style rims on reflection
Apr 28, 2007 20:06:17 GMT
I had a bit of a result today. The paint I bought for the wheels had lids of a perfect size; Just need to get the stickers off. Dave
Apr 28, 2007 21:57:50 GMT
i see you've found that the rattle can lids have fitted the bill, just thought i'd add, a friend had an old datsun with tasty rims but no caps, he used some polystirene (xcuse my cack spelling) cups sprayed matt black & i gotta say they looked pretty tidy, you really would know!
looking good those ims i must say! i seen a nice tye 3 today, althogh not a big vw fan it looked great, biege on high/mirror polished brm's mmmm
thse red band tyres!!! badass! bring back some 50's styling ques i say
Mini 998cc grp bonnet & boot, lightend shell, 6-point cage, soon to have a turbo on the 998 engine (t2 frm a r5gt) rs turbo intercooler, hoping to get 120ish bhp?
father is building a Mini Van 1330, 45 weber, 100bhp@wheels
'RIP' 1.8 Metro GTi, 15.23 1/4mile
Apr 28, 2007 22:10:00 GMT
woohoo. i already have the car to suit. now where do i go about getting a set of theses puppies?
Apr 28, 2007 22:32:22 GMT
Funnt you should ask, 3/4 of the way down the link I posted (http://www.vwscotclub.co.uk/forum/forum_posts.asp?TID=3423) there is somebody called Davey selling 2 sets.
sav
Apr 28, 2007 22:43:07 GMT
Looks like they should do the job ok
Apr 29, 2007 20:07:15 GMT
I masked and painted these wheels today and I think the tin lids look great; Just for comparison sake, here is how they looked before I started working on them; Best bit is the 5 of them only cost me £20 with 2 good tyres (that I wont be using) to buy so total cost is about £100.
bobz
Apr 29, 2007 20:12:57 GMT
They look great mate, and what a bargin!!!! ;D
Don't plan anything, it'll start raining!
