Mk3 golf vr6 in Dark Grey.
Factory VR6 but now running the 2.9 Corrado lump.
Has MOT till December and tax till the end of May 2014
The sills are straight and not crushed ( very uncommon on mk3 golfs as many will know) It had small bit of welding on the floor where the gromit had rusted out a bit ( again common ).
The body is straight. However not perfect. It has a dent on the passenger wing. The rest looks all good and clean. It could do with a clay, cut and polish though.
The car needs a new windscreen. It has a big crack on the passenger side. Had one replaced before for £100 so not expensive. Just can not afford to sort it as buying a house at the min.
The interior is good and clean. There are no rips or tears in the upholstery. Everything is there. It has a momo steering wheel and some boss. The airbag light was removed due to not running an airbag on the driving wheel anymore.
The car is ready for a service. I am using it daily at the moment and havent had time recently to sort it. The engine does not have any chain rattle. It is running 10mm leads. The exhaust is stainless from cat back. A mix of powerflow and Jetex. It gives a great noise. The air filter etc is all standard stuff.
The car is Located in Coventry, West Midlands
You can contact me on here or on zero 7496 5 hundred 887
I am looking for £1100
I will sort some much better pics over the coming days.
