Dez
Club RR Member Number: 34
Apr 26, 2007 11:38:48 GMT
i hate british electrical systems!! I'm more used to working on german stuff, that actually has things like a fusebox ive spent most of the morning messing with the commer to get it MOTable, sorted out loads of electrical problems, the only remaining one now is wipers. theres only 3 wires, how can it not work?! black=earth. one green wire runs all the way to the live feed block. black w/green runs to switch, other side of switch is earthed. thing is, both of them are live ive bypassed the switch and all the wiring to check its not that, so it looks as though the wiper motor doesnt work (like anything else that says LUCAS on it) if its fecked theres no hope of another one before tomorrow, so no mot
Apr 26, 2007 11:44:45 GMT
Apr 26, 2007 11:47:49 GMT
you need this then (excerpt from an old e-bay advert); Description Have you inadvertantly let the smoke out of the wires on your classic British car? This, then, is the solution to your problem! Here is presented for your perusal one Lucas Replacement Wiring Harness Smoke kit, P/N 530433, along with the very rare Churchill Tool 18G548BS adapter tube and metering valve. These kits were supplied surreptitiously to Lucas factory technicians as a trouble-shooting and repair aid for the rectification of chronic electrical problems on a plethora of British cars. The smoke is metered, through the fuse box, into the circuit which has released it's original smoke until the leak is located and repaired. The affected circuit is then rectified and the replacement smoke re-introduced. An advantage over the cheap repro smoke kits currently available is the exceptionally rare Churchill metering valve and fuse box adapter. It enables the intrepid and highly skilled British Car Technician to meter the precise amount of genuine Lucas smoke required by the circuit. Unlike the cheap, far-eastern replacement DIYsmoke offered by the "usual suppliers", this kit includes a filter to ensure that all the smoke is of consistent size, It has been our experience in our shop that the reproduction Tiawanese smoke is often "lumpy", which will cause excessive resistance in our finely-engineered British harnesses and components. This is often the cause of failure in the repro electrical parts currently available, causing much consternation and misplaced cursing of the big three suppliers. These kits have long been the secret weapon of the "Ultimate Authorities" in the trade, and this may be the last one available. Be forewarned, though, that it is not applicable to any British vehicle built after the discontinuing of bullet connectors, so you Range Rover types are still on your own... This Genuine Factory Authorised kit contains enough smoke to recharge the entire window circuit on a 420 Jaguar, and my dear friend and advisor George Wolf of British Auto Specialty assures me that he can replace ALL the smoke in a W&F Barrett All-Weather Invalid Car(147 CC) with enough left over to test a whole box of Wind-Tone horns for escaped smoke. How much more of an endorsement do you need? More, you say? Well, I once let the smoke out of the overdrive wiring on my friend Roger Hankey's TR3B, and was able to drive over 200 miles home from The Roadster Factory Summer Party by carefully introducing smoke into the failed circuit WITHOUT even properly repairing the leak. Another friend, Richard Stephenson, was able to repair the cooling fan circuit of his Series 1 E-type by merely replacing a fuse and injecting a small quantity of smoke back into the wires. So there! So, if you're troubled by lost smoke, bid early and bid often! Thanks for looking! see the other lucas thread for all the Q&A's.......brilliant stuff.
71 Alfa GT 1300 Junior 89 Alfa 75 3.0 V6 Veloce 89 Alfa 75 3.0 V6 America 2015 C220 estate Daily shunter
Dez
Apr 26, 2007 12:12:04 GMT
well, i made a cup o' char, and went back out with my 'english car mechanic' head on. i used the classic britsh car mechanics method to ensure 100% success. whilst holding tea in one hand, i used a 4lb adjusting stick on the wiper motor with the other, works fine now well, it scrapes the wipers across the screen in a painfully slow, jerky motion accopanied by wining noises. factory fresh that smoke is quality, does it have the burnt plastic aroma too or do i have to buy that seperately? i need to get a new bag of 'wiring loom sparks- assorted sizes' too.......
Apr 26, 2007 12:15:58 GMT
well, I made a cup o' char, and went back out with my 'english car mechanic' head on. I used the classic britsh car mechanics method to ensure 100% success. whilst holding tea in one hand, I used a 4lb adjusting stick on the wiper motor with the other, works fine now I've found you can make it work a bit quicker if you shout 'Work you curse word!' while 'adjusting' the item in question ;D
Apr 26, 2007 18:28:28 GMT
TBH I have found most Lucas electrical systems I have had in many cars I have had to be fine. I don't know what everyones complainaing about, especially not the yanks with their insane wiring systems - like fusible links or the bizarre habbit of routing the entire wiring loom for the vehichle through the light switch meaning that the headlamp switch has about 40 connections to it.... Those truely are awful and thats the way about every yank car from 1945 to 1990 is wired. crappola.
Dez
Apr 26, 2007 20:25:24 GMT
my falcon wagon is wired like that. when the lightswich gets hot it randomly fades the lights up and down...
spacekadett
F*cking take that Hans Brrix!!
Apr 26, 2007 20:46:58 GMT
I feel your pain Oh the hours I've spent up to my armpits in tape and scotchloks on old Landys, Minis and kit cars. Thats mainly at work tho, so at least I was getting paid BTW, always remember, if all else fails if you don't have a screen, you don't need wipers
Mechanic's rule #1... If the car works, anything left on the floor after you finished wasn't needed in the first place
