'Ow do.
This is my awld triumph in need of a bit of love. I took in exchange for my beasty landy a little while back and must accept that I have too many car shaped things. I've not been underneath this but had a quick look and stuck my head under and it doesn't look too bad. Will obviously need a touch/punch of mig depending on what finish you wanted but is by no means a basket case. I have a large file of history with it showing that it was restored at what must have been great cost some time ago.
The interior seems complete and has an awsomesauce period pattern. damage to drivers seat as seen in photo but otherwise not too bad. Sliding roof will need attention as you would expect.
Engine doesn't run, I did go to try but after adding some fuel discovered there's a leak from somewhere at the back and didn't have time to get any further into it. There's a couple of little bits removed (they may be inside?) like a lead and the dizzy cap but the main event is present and correct.
There you have it, if you want a look just let me know, I've driven it being towed for a good half mile and it was satisfying, but these aren't my bag really.
I'm after £500 please.
