Apr 15, 2014 16:52:43 GMT
A friend of mine owns a Vectra C which has a annoying fault.
Hen the vehicle is parked the light on the rear left cluster stays on as if the headlamps are on. I've checked it's not the parking light. I've changed the board the light bulbs go into and the bulb however the light stays on constantly as I say it's definitely not the parking light but does look like it. The front lights are off can anyone help please !!!
Apr 15, 2014 18:05:36 GMT
has it a tow bar? if so have you checked the lektricks on that?
Rich
Club RR Member Number: 160
Apr 15, 2014 18:45:34 GMT
Vectra C? Yea. That won't be the bulb PCB, it'll be something like the SIM unit or the electrical centres. You need a FULL code read or a trip to an auto-sparky. That doesn't sound like it's going to be a simple fix.
Apr 15, 2014 19:10:29 GMT
I was hoping to avoid that it's annoying how what should be a simple fix is so complicated
Apr 15, 2014 19:10:44 GMT
No tow bar
Rich
Apr 15, 2014 19:41:41 GMT
I was hoping to avoid that it's annoying how what should be a simple fix is so complicated Its modern, it won't or ever be simple. And I don't say that as one of those 'modern car doomsdayer' people, I am a tech at a used car forecourt, and 9 times out of ten people part-ex because they want out of something with a fault.
Apr 15, 2014 21:06:23 GMT
I was hoping to avoid that it's annoying how what should be a simple fix is so complicated Its modern, it won't or ever be simple. And I don't say that as one of those 'modern car doomsdayer' people, I am a tech at a used car forecourt, and 9 times out of ten people part-ex because they want out of something with a fault. That's the truth I have got back into working with cars and they are sooooo complicated now I stupidly thought swapping the light cluster would sort the problem :-)
Apr 15, 2014 21:45:15 GMT
any spares head over to pick a part in Erith cheapest in the area. and loads of Vectra C's in atm
Apr 15, 2014 22:19:14 GMT
Thanks mate
TS
Apr 18, 2014 12:43:36 GMT
Would a battery immobiliser not be a cheap fix?
Apr 18, 2014 17:33:36 GMT
Would a battery immobiliser not be a cheap fix? Would it not cause a issue come mot time ?
TS
Apr 23, 2014 19:21:57 GMT
No idea
Apr 23, 2014 20:16:34 GMT
Sounds wrong but try changing the indicator relay - if they are anything like the Corsa C's they fail randomly and cause all sorts of wierd and wonderful problems, also have you checked they aren't leaving the indicators turned on when parking?
Apr 23, 2014 22:52:01 GMT
I did think it was the parking light but I'll try changing the indicator relay thanks mate
Hi, did you ever get this problem sorted. If so what was it. I have the same problem on my vectra c 04 and trying all sorts of things to resolve it. Doing my head in not knowing.
Make sure the doors are all closed. Wires in the harness where it goes from the body into the door eventually breaks. I had the same problem. Started with the window not working on the passenger door card,then light coming on. Eventually no more central locking,could only lock with the key. Auto electrician sorted it out while I waited,said it was pretty common...It does have to be re flashed with a code reader,as it uses canbus....
Last Edit: Jul 3, 2016 15:53:21 GMT by Deleted
