dpb
right i have a mk3 capri, i have taken the inner light out which is full beam. i want to change the out light so it is main beam and full beam I know it can be done as i have seen people have done it before. i just need help on what i need and how to do it, if anyone could tell me that would be great
cheers
Rich
Club RR Member Number: 160
mk3 capri light help!!Rich
@foxmcintyre
Club Retro Rides Member 160
Apr 14, 2014 10:25:49 GMT
'Main' beam and 'full beam are the same thing. You need to find appropriate headlights in the correct size, That take H4 bulbs. Shouldn't be hard, they are readily available.
Copey
Apr 14, 2014 10:34:08 GMT
'Main' beam and 'full beam are the same thing. You need to find appropriate headlights in the correct size, That take H4 bulbs. Shouldn't be hard, they are readily available. This, get on eBay and search for 5.75" h4 headlights
dpb
Apr 14, 2014 18:10:32 GMT
I ment dipped haha so I have all three in the outer light. Do I not need to change wiring and stuff ?
Cheers for the help so far guys
Apr 15, 2014 13:15:21 GMT
Bulbs only require a power and a negative. The negative goes to the body of the bulb and the power goes to the terminal. On the H4 bulbs you have two power terminals and one negative terminal. One power wire is your full beam, the other power wire is your dipped beam. You could do the conversion without a volt meter as you just have to remember which wires were originally connected to what. You could also by trial and error although that's not usually the best approach with electrics.
dpb
Apr 19, 2014 17:52:50 GMT
lost me abit ejenner, so do i use the wires from the full beam and try connect the time the outer light ?
Apr 20, 2014 10:13:15 GMT
If you are converting to a single lamp then the H4 bulb will have 3 terminals on it. One is earth, two are power. One of the power wires will be for dipped beam, the other for full beam.
