Thanks!
The car is by no means "finished" but other obligations in life means that I can't spend all the time on the car. Last weekend we had a rather large car meet here and I spent some hours tidying up some small stuff and gave it a good wash and wax. The car creates some interest from people who know but it's a bit stealth to the un-initiated. I had a good day out though.
On the way back from the last track day I had some small misfires when cruising. On the way to and from the car meet it got worse. Every time the car would misfire, the shift lights would also flicker. That lead me to think I had some noise on the crank signal. But since I still run a complete EDIS system with EDIS module, it should be pretty tolerant. I checked the wiring in the engine bay and found no signs of error.
Last night I went for a drive with the computer connected to log the issues.
Rather nice way to search for problems...
The log files actually did not show the rpm spikes I anticipated, but you could see that the AFR would spike high and sometimes other sensor values spiked too. So I dove deeper into the wiring and found a loose earth connection for the engine management loom, on the relay plate. I tightened that up nicely and the issues went away :-) Simple problems are sometimes good problems.
Sunday is the last (?) track day of the season. Now I need to find time to dis-attach the rear ARB and swap to the racing wheels again.
Gustaf
Gustaf
